1978 - 1996 Big Bronco
Taligate handle release assembly
Old Aug 5, 2008 | 07:54 PM
Outdoors1's Avatar
Outdoors1
92 Bronco. On the tailgate handle release assembly there is a rod that runs from it to the bottom of the tailgate. The rod is apparently anchored at the bottom and does not move. Where does it attach to the handle release assembly and what does it do? Or does it attach somewhere other than the assembly? Does anyone know the rod I am referring to? Thanks.
Old Aug 6, 2008 | 07:54 AM
Campbell 56's Avatar
Campbell 56
Thumbs up
Sounds like what I would call the "tailgate window safety rod" or something like that. I don't know what Ford calls it. It should connect on the latch/handle mechanism to a lever that blocks the handle from moving when the window isn't all the way down. Look for a lever that is pointed at the left (driver's) side of the tailgate when you have the tailgate down. I used a mirror to see in there just last week when I was connecting it all back up. There should be a plastic snap on thing that will hold the rod end in the lever. When the window is rolled down, it contacts the rod and moves it down and that swings the lever out of the way of the latch so you can pull the handle and open the tailgate.
Hope this helps!
Old Aug 8, 2008 | 07:53 AM
Outdoors1's Avatar
Outdoors1
That does help. Thanks.
whome80f100
Sep 22, 2012 09:42 AM
jimmmack
Jun 11, 2011 03:33 PM
Old Rust Bucket
Paint & Bodywork
Dec 11, 2007 03:01 AM
lsdengines
Nov 2, 2007 09:48 PM
EBrown
1983 - 2012 Ranger & B-Series
Dec 20, 2006 05:53 PM
