Having a problem with my tailgate
Old Nov 2, 2007 | 10:57 AM
lsdengines's Avatar
lsdengines
The other day I noticed the tailgate wasn't wanting to release. I didn't have time to mess with it til this morning. I took the handle off so that I could get to the rods inside the tailgate. The passenger side releases when you pull it, but the drivers side does not. It moves freely about 1/2-3/4" then its like it hits a wall. It is still attached on the latch end. It is a 72 f100 swb explorer. Any ideas on how to get the tailgate open? Thanks.
Mike
Old Nov 2, 2007 | 11:46 AM
jowilker's Avatar
jowilker
Mike, Keep pulling on it and then lube it up. It should start working again. I hate to tell you to go at it with a screwdriver, but you may have too.
Working from the hole, get something hooked into it and use some kind of impact to move it.
John
Old Nov 2, 2007 | 09:27 PM
lsdengines's Avatar
lsdengines
I wont get a chance to check it out again til tommorrow evening, but I'll see. Thanks.
Old Nov 2, 2007 | 09:48 PM
Customcab's Avatar
Customcab
I don't recall exactly how the rod is attach; but some tailgate models; had the ability to screw / turn the rod acouple of turns to reduce the lever pull. I'm not 100% sure our trucks are capable of adjusting the linkage of the rod. I'll also check mine tommorrow morning on my 78; its expose alittle.
Mitch
MS86
Jun 24, 2015 02:57 PM
Tim Hodgson
1978 - 1996 Big Bronco
Jun 10, 2013 04:34 PM
StillAqua
1983 - 2012 Ranger & B-Series
May 19, 2010 01:24 PM
1973FordF100
Oct 28, 2008 02:05 PM
EBrown
Dec 20, 2006 05:53 PM
