5r55e trans. problem
Old Aug 5, 2008 | 06:38 PM
ldsgrem's Avatar
ldsgrem
i have a 2001 sport trac that the ovrdrive is not woking properly. it wants to slip if you keep overdrive on(od light starts flashing also) but if you turn overdrive off it shifts fine. transmission shops wat 1500.00 to rebuild but i pulled pan off and theres very little metal on magnet. could anyone give m any advice on this..thanks..lynn
Old Aug 5, 2008 | 07:35 PM
jk080's Avatar
jk080
Transmission Rebuilder
Sounds like the overdrive band is broken (these bands are known to break).
The only way to tell is to turn the front adjustment screw in, if it will turn in more than three turns the band is broke.
Old Aug 5, 2008 | 08:20 PM
ldsgrem's Avatar
ldsgrem
5r55e trans poblem
where is the screw located at...thanks..lynn
Old Aug 6, 2008 | 01:16 AM
Bear River's Avatar
Bear River
Former ******
The another common problem is that the bores that engage the bands have a side load on them due to the way they engage the bands at an angle. If they wear enough, they do not engage the bands fully resulting in slippage.
Old Aug 7, 2008 | 10:42 PM
steve(ill)'s Avatar
steve(ill)
https://www.ford-trucks.com/forums/588191-5r55.html
Prozon
Offroad & 4x4
Aug 12, 2008 10:35 PM
DadzzTazzDullie
Mar 4, 2008 06:25 AM
THRODS
Modular V10 (6.8l)
13
Apr 14, 2005 09:57 AM
Diesel Daddy
Nov 10, 2003 09:52 PM
stecz
Aug 9, 2003 03:20 PM
