Sponsored by: Auxito
Water leak?
Old Aug 5, 2008 | 10:32 AM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
Water leak?
Checked my water level the other day and it was a bit low. I also noticed that when i pulled off my resevore cap there was no pressure. Im assuming i have a leak in my system somewhere. But i done see any leaks, cant smell anything sweet in the exhaust. And the thing runs like a top.
Im a bit worried, but i really have know idea how to handle it.
Any thoughts.
Old Aug 5, 2008 | 08:56 PM
Thomas Hutchins's Avatar
Thomas Hutchins
If it was cool or cold, there should not be any pressure, in fact if cold, there may be some degree of vacuum. The vacuum occures as the hot coolant cools and contracts. The cap opens at about .5 in of vacuum and draws coolant from the resivour into the rad. If the resivour is low or empty, the vacuum could have opened the cap and drawn air into the rad and eaqualized the pressure. I suggest that you fill up the resiviour to the correct mark and drive the unit for twenty miles or so and then let it cool down for 4 to 5 hours, and check the level in the resivour.
Check the under side of the water pump for sign of a slight weep or leak. I believe that there is a weep hole on the under side of the pump.
Old Aug 5, 2008 | 11:01 PM
BURNSTOUGHFORD
ya there should be a weap hole, i understand exactly what your talking about, but thats why im worried because there is normally pressure.... anyways well see what happens
Old Aug 7, 2008 | 10:34 PM
steve(ill)'s Avatar
steve(ill)
look in the VEE of the motor behind the alternator. i had a leak in the cross over tube bolted to the bottom of the manifold at the front passenger side bottom. i noted after the antifreeze got on the front plug and shorted it out.
Old Aug 8, 2008 | 04:44 AM
royallenz06's Avatar
royallenz06
it could be leaking through your intake gaskets and going into the cylinder but at a very slow rate and you will not smell it in the exhaust. if there is no visable leak outside it has to be inside. i have seen several 5.4s leak through the intake gaskets.
Old Aug 8, 2008 | 07:18 AM
Johnny Langton's Avatar
Johnny Langton
Or,it's a slowly leaking heater core.
JL
95PSDieselP
Dec 8, 2010 12:16 PM
alexchavel
Aug 8, 2009 02:18 AM
FourbynFord
Dec 18, 2006 08:34 AM
JustinH
1997 - 2003 F150
Feb 5, 2004 02:33 PM
Bob_Smith
1978 - 1996 Big Bronco
Sep 22, 2003 12:32 AM
