No backup Lights
Old Jul 5, 2002 | 09:07 AM
Luis_3's Avatar
Luis_3
No backup Lights
I own a F150 1992 Automatic Transmission coming with towing package. The Backup lights are not working, obviously bulbs are Ok.
Can anyone give me some hints where to check?
Thanks in advance.
Old Jul 5, 2002 | 09:47 AM
kioolt's Avatar
kioolt
No backup Lights
If you have a E40D automatic the backup light switch is part of the manual lever position sesnors mounted on the transmission. If you have a C6 or AOD transmission the backup light switch is part of the park/neutral switch also on the transmission. I would check there if your fuses are good.
Old Jul 5, 2002 | 10:01 AM
1968F250LWB's Avatar
1968F250LWB
No backup Lights
[updated:LAST EDITED ON 05-Jul-02 AT 11:02 AM (EST)]To check either one of those switches, put transmission in reverse. With truck engine off of course. Put key in run position and check for 12VDC at back up light. If no voltage is there than trace the wires back and check at the next available place and so on an so forth. If you do have voltage there than check your ground connection, ensure the area it is attached to is clean and paint free.
Russell
1968 F250 LWB 300-6
FORD=First on Race Day
MOPAR=Mostly Old Parts and Rust
Old Jul 19, 2002 | 08:08 PM
Luis_3's Avatar
Luis_3
No backup Lights
thanks a lot, i solved the problem. A fuse at engine compartment wasn´t ok. just replaced and backup lights are working again. Thanks for information.
Old Jul 20, 2002 | 12:07 AM
Mil1ion's Avatar
Mil1ion
No backup Lights
jvmcc
Nov 24, 2014 05:36 AM
73FOMO
Dec 28, 2011 01:59 PM
trevorwithf-350
Apr 21, 2007 09:19 PM
bellpr
Jun 9, 2004 03:30 PM
RandysF150
Oct 1, 2002 11:48 PM
