frame specs
Old Aug 5, 2008 | 06:54 AM
black58's Avatar
black58
frame specs
Hey guys, I tried over on the 67-72 forum, but go no response. I know all about the problems with swapping frames, both of my trucks are in a storage garage right now so I don't have either of them available for reference. I have a 58 and a 68. If it fits, I would like to swap the 58 tin on the 68 frame. How wide is the 68 frame from rail to rail. I can shorten it if I need to, no problem. But if it's too wide, I guess it's too wide. I have a buddy that's interested in the 68, but I don't want to get rid of it if I can use it. Thanks, John
Old Aug 5, 2008 | 11:27 AM
mcdonaldm's Avatar
mcdonaldm
frames should be the same width as the rear ends swap between the trucks no problem. i suspect the front track width should be the same also.
now as far as body mounts and frame shape, that i don't know how close they are. might have to do some fab work to get the 58 to fit on the 68 frame.
rgds
Mike
Old Aug 5, 2008 | 11:41 AM
black58's Avatar
black58
rgds
Mike
Thanks Mike, I figured the mounts would be slightly different, but workable.
H_A_S_R
34
Aug 3, 2011 08:57 PM
averagef250
Nov 4, 2004 07:05 PM
jniolon
Apr 12, 2002 11:19 AM
