6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
6.4L Maintenance
Old Aug 24, 2008 | 06:58 PM
  #31
Mnytalks1's Avatar
Mnytalks1
This will sound like a stupid question but what good is logging into that site? Does Ford log all my oil changes and etc for warranty purposes in the future? I'm just trying to figure out if I really need to spend that type of money at Ford or if doing it myself would be ok.
Old Aug 24, 2008 | 07:53 PM
  #32
jasfaa's Avatar
jasfaa
Every service item they do is tracked. By law you do not need to have the work performed at a Ford dealer but for the warranty to be in place you need to make sure you notify them of your oil changes, filter changes, etc. Just make sure you do the maintenance schedule in your manual and you will be fine along with notifying them so they can log you did the routine maintenance yourself so your warranty will not be affected.
Old Aug 24, 2008 | 09:36 PM
  #33
Mnytalks1's Avatar
Mnytalks1
I read about doing a water seperation every month or so. Is that actually required or should it only been done when instructed by the console.
Old Aug 24, 2008 | 10:54 PM
  #34
jasfaa's Avatar
jasfaa
You have to do your maintenance the way you want. I have always changed out my fuel filters every 15000 or every other oil change along with the air filter. I have not done one on this yet though so it is a little over due.
Old Aug 26, 2008 | 05:27 PM
  #35
69cj's Avatar
69cj
I went to "My Ford.com" and set up my maitenance items there. Everything related to warranty I log in there under the maintenace heading. Makes it easy, just keep your receipts for parts and oil.
Old Aug 26, 2008 | 07:25 PM
  #36
Carl Lassiter's Avatar
Carl Lassiter
Just do it once a month if rig's in regular use. Takes only a minute. Yellow hose under drivers side of cab
Old Aug 26, 2008 | 09:15 PM
  #37
case_7010's Avatar
case_7010
i just picked up a motorcraft oil filter and went to my tractor dealer and bought a five gallon bucket of 15w40 cj4 john deere engine oil. cheaper than motorcraft and just as good if not better. think ford will care?
CaptainMarvel
1997 - 2003 F150
Mar 19, 2015 12:52 PM
caskillet
Oct 19, 2014 05:59 PM
Keith1984
Feb 17, 2007 05:16 PM
JohnBoy2
2004 - 2008 F150
Nov 27, 2003 04:54 PM
Denied
Modular V10 (6.8l)
Nov 11, 2003 11:27 AM
