HPOP part number!!!
Old Aug 9, 2008 | 01:00 PM
  #31
fishmanndotcom's Avatar
fishmanndotcom
sweet! man!
did you happen to have a hard time getting the nut off the HPOP gear? i feel like all i am doing is spinning the pump with the nut.
any and all suggestions are welcome
-cutts-
Old Aug 9, 2008 | 01:51 PM
  #32
tjbeggs's Avatar
tjbeggs
You will need to get a breaker bar on the crank pulley bolt to hold the engine with loosening and torquing that bolt. I have used an impact wrench before but that was out of the truck.
Old Aug 9, 2008 | 04:26 PM
  #33
glasseater's Avatar
glasseater
Originally Posted by fishmanndotcom
sweet! man!
-cutts-
i had no problems, so listen to tim on this haha
Old Aug 10, 2008 | 10:19 AM
  #34
fishmanndotcom
my girl came by yesterday after posting so i havent had a chance to get back out and work on it again till this morning. i must be doing something wrong... i have a breaker bar on the crank pulley nut and the HPOP gear is still spinning. i thought maybe it is a left handed thread but i very soon found out it is not (definitely feel it getting tighter). i feel i am so close yet so far! helppp!
anymore ideas/tips/tricks?
EDIT:
ok after some more pulling, grunting, and breaker barring i got it off! the pump is sittin in the garage and the oil is drippin in the pan. i am now following Cody's step #38 - sit down, relax, and crack a brew!
-cutts-
Old Aug 10, 2008 | 11:46 AM
  #35
fishmanndotcom
ya know... if i didnt have bad luck i dont think i'd have luck at all! i pulled the pump out and set it on the core support so i could jump down (i have a ranch hand bumper so it makes for a nice place to stand and work on stuff) and swap the fittings. however while moving down the bumper and jumping off i rocked the pump enough to where it 'rolled' off the core support and on the concrete floor. at first i thought everything was fine but after closer inspection the 37* sealing face on the 90* fitting took a nice whoolap and there is no way (i dont think) it will seal and i am NOT doing all this again bc i want to find out if it will leak.
Question... i know on one side this is a JIC fittings, what about the other side? is it a standard pipe fitting? anyone know if i can even find this stupid thing by itself? or will i have to buy me another pump just for the fitting?
BTW... glasseater, i am really sorry for hi-jacking your thread. i didnt really take notice until now but it all kind of fit in the same topic and maybe someone will find this helpful in their endeavors! i will start a new thread if you would like me too!
-cutts-
Old Aug 10, 2008 | 12:44 PM
  #36
fishmanndotcom
after some deep diggin i think i may have found the answer... tell me if i am somewhere in left field.
according to Swamps this is the fitting HPOP
Originally Posted by Swamps
This single fitting will be a 90degree fitting # 5 "male boss" (sometimes called # 5 o-ring) on one end of the 90, and a # 6 male JIC on the other end of the 90. Our local hydraulic shop would label such a fitting as 5MB-6MJ90
so i looked it up on Surplus Center and this is the fitting i get...
which according to them....
Originally Posted by Surplus Center
JIC Male To SAE Male Long 90° Elbow
Brand new, corrosion resistant, plated steel hydraulic fitting.
SPECIFICATIONS
* JIC 6M to SAE 6M long 90° elbow
* Shpg. 1/4 lbs.
however... on Swamps site it says a #5 Male boss (or o-ring fitting and all i am finding is #4 or #6, no #5. and it states SAE, not Male Boss!
am i on the right track here?
-cutts-
Old Aug 10, 2008 | 04:47 PM
  #37
BlueMule's Avatar
BlueMule
A #5 male boss fitting fits the oil rail in the head, #6 male boss is the one for the pump. The one you pictured from Surplus Center is the right one.
Or send me a PM with your address and I'll send you one. I have extras from when I was doing the plumbing on my pumps.
Old Aug 10, 2008 | 05:18 PM
  #38
glasseater's Avatar
glasseater
-cutts-
haha it's fine man use this thread as much as you want, it's all related and here to help people!!!! by the way yes that is the fitting
Old Aug 10, 2008 | 05:57 PM
  #39
RubberDuck's Avatar
RubberDuck
Jason, relax brother. I emailed you already, but if you didn't get it. I have those fittings all day long. Between Rodney, and myself, you should be okay. LOL Good job Rodney.
Old Aug 10, 2008 | 09:18 PM
  #40
fishmanndotcom
thanks Cody... i did respond!
thanks a ton fellas! i was worried that these fittings are from Ford or IH only but if they are readily available i will run by my local hydro shop tom and have them make me a HPOP pressure gauge as well as the fitting!
thanks again guys!
-cutts-
Old Aug 10, 2008 | 09:21 PM
  #41
RubberDuck's Avatar
RubberDuck
thanks again guys!
-cutts-
Okay, now you suck.... I want one of those manual gauges too. But I never think about it at the right time. I have the DiPricol electric on that plugs to the ICP sensor, but a manual would be alot cooler. Good luck man, let us know how it turns out.
Old Aug 12, 2008 | 01:36 PM
  #42
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
Originally Posted by RÖENTGEEP
Well, Im confused
I have read different PN for the IH 17* HPOP.
Which is the good one.
PN. IH:
2589446c91<O
1815874C1
<O1831449C91
<O
Originally Posted by glasseater
PN. IH: 1815874C1<O
<Othat one is bad, i tried it and it's just an o-ring
So what about the other PNs, are both ok?
Old Aug 12, 2008 | 08:54 PM
  #43
fishmanndotcom
well i hope the 1831449C91 is correct because it is the one i just finished installing.
speaking of... i have a two prong connector on the driver side of the engine. i cant figure out what it plugs into! i thought i thought of everything! lol
-cutts-
Old Aug 12, 2008 | 09:11 PM
  #44
tjbeggs's Avatar
tjbeggs
EBPV on turbo pedestal?
Old Aug 12, 2008 | 11:11 PM
  #45
fishmanndotcom
yup... i had it unplugged before but never really noticed the other side of the plug! thanks
-cutts-
