Cigar Lighter Won't work.
Old Aug 14, 2002 | 03:15 PM
1968F250LWB's Avatar
1968F250LWB
[updated:LAST EDITED ON 14-Aug-02 AT 04:21 PM (EST)]I am trying to get my lighter to work in my 68. I connected the blue/white stripe wire to the connector and made sure I sanded the dash to baremetal where it goes into it. It still doesn't work. There is 12VDC on the blue/white wire and .6 ohms of resistance between the lighter casing and a known good ground. I know the lighter is good cause I bought it here from Ken. Any help would be greatly appreciated.
Russell
1968 F250 LWB 300-6
FORD=First on Race Day
#88 Dale Jarrett
#21 Elliott Sadler
#97 Kurt Busch
#28 Ricky Rudd
Old Aug 14, 2002 | 04:20 PM
sparky's Avatar
sparky
Well if you have a good ground and you have 12 volts the only real thing left is a bad lighter
Unless the power wire has a corroded connection or a corroded section somewhere between the lighter and the fuse. I have seen these type problems before, usually in the tail light circuit, you can measure 12 volts but as soon as you try to use that voltage it drops to 0.
Maybe try running a "temporary" new wire to the lighter. That way you can verify the lighter works, and if it does it is a wiring problem. If not you got a bad lighter.
Sparky
Old Aug 14, 2002 | 06:35 PM
1968F250LWB
Sparky UDAMAN! It worked when I bench tested it with my 115VAC to 12VDC converter. Installed in dash and ran a test wire and it worked there also. Sprayed some cleaner in the connector but it still didn't work. Re-checked vlotage and it was 12VDC at fuse but dropped to 10VDC at connector. Looks like I just need to run a new wire. Thanks man,
Russell
1968 F250 LWB 300-6
#88 Dale Jarrett
#21 Elliott Sadler
#97 Kurt Busch
#28 Ricky Rudd
Old Aug 14, 2002 | 10:35 PM
sparky's Avatar
sparky
No prob. Glad I was of assistance.
Sparky
ps
Doesnt the Surgeon General warn you not to smoke.....
Old Aug 15, 2002 | 03:50 PM
redneckdieselmechanic's Avatar
Frmnsal
15
May 28, 2018 04:04 PM
Darrinsuwinski
2004 - 2008 F150
Jan 28, 2017 01:08 PM
oceantrav
Jan 11, 2017 04:43 PM
t-bone31
Mar 14, 2016 07:36 AM
1968F250LWB
Jan 8, 2003 12:52 PM
