Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Hybrid A/C Performance
Old Aug 2, 2008 | 10:39 AM
bhenders's Avatar
bhenders
We have an 07 Mariner Hybrid, about 11K miles. Interested in what others have experienced regarding A/C performance. I fully expected the cold air flow to subside when you come to a stop and the engine shuts off.
However, with our Hybrid the correlation is with vehicle movement! No kidding, we stop at a red light, the engine is still running but the air flow fairly quickly changes from cool to "medium". Given the hot weather of late one can get pretty uncomfortable at just one light. If you have a series of red lights you have to give up on the A/C and put the windows down. Same result Max A/C or not. Anyone else dealing with this!
Thanks!
Old Aug 2, 2008 | 05:07 PM
Maddog521's Avatar
Maddog521
I have an 07 XLT non hybird and I have noticed the same. I thought that maybe it happened because it is 106 degrees. I have checked this several times and it never changes. I am going to the dealer to see what they say.
Old Aug 3, 2008 | 07:39 PM
Nitramjr's Avatar
Nitramjr
I have an '05 and an '06 and what you are describing isn't normal or typical of the hybrid Escapes. Your '07 is almost identical to the '05 and '06 models.
I don't use the a/c very often but when I do, I use it on the gas saving mode that allows the gas engine to shut off. On the rare days that is is brutal hot here I will use the "red" setting (MAX A/C) and both of mine stay very cold in this setting.
A couple possibilties are your a/c needs charging or you have a dirty cabin air filter. There were some issues with the early hybrids losing a/c charge at low miles but I don't know if that issue existed in the '07. Also, unless you put a cabin air filter in, yours isn't dirty since they didn't come with one installed.
It might be worth having the dealer check your a/c system out since the a/c also has cooling lines that run to the back and keep your high voltage battery pack nice and cool.
Good luck.
Don53713
Jan 6, 2014 08:19 AM
dgags
Nov 23, 2012 12:49 PM
Brigart
Aug 25, 2011 02:22 PM
i eat hybrids
Apr 20, 2011 08:31 PM
Nitrous
Jul 23, 2010 09:17 AM
