P0528
Old Apr 19, 2011 | 01:30 PM
i eat hybrids's Avatar
i eat hybrids
P0528
My truck keeps throwing a code which is P0528 fan speed sensor no circuit, according to my edge insight. Now my question is, would this affect my air conditioning? Because during the summer my A/C is very *****ty. At idle it only blows out warm air and is bearly cold once you get up to speed. Ive recharged the A/C to ford spec, their isnt any leaks, and i checked the gap spacing in the A/C clutch. Im running outtta ideas.
Old Apr 19, 2011 | 01:48 PM
texans's Avatar
texans
That code is for the VSF check the wiring to the fan clutch (espcialy where it plugs in at the shroud) If all wires look good then you will probably need a new fan clutch. This is probably the reason for running a little hot (just got done reading your other post about that). As far as the A/C goes I don't see how this would effect it other than the condensor will be getting hot sitting in front of the Radiator. That could cause your problem. I would fix the p0528 code first then see what happens. Also make sure the condensor and stuff aren't pluged up with dirt and debri. That would all so cause a poor A/C performance at idle.
Old Apr 19, 2011 | 02:09 PM
i eat hybrids
The A/C just sucks period. But at idle its terrible. Condensors clean! lol.
How hard is the fan clutch to replace? and can this be covered under the 2 year/200k mile extended diesel eng care from ford?
Old Apr 19, 2011 | 02:51 PM
texans's Avatar
texans
I have no Idea if it would be covered under the ford warrenty or not. It's not really hard to do for your first time doing it I would count on 3-4 hours!
Old Apr 19, 2011 | 03:23 PM
i eat hybrids
Ok looks like ill be doing that before it gets to hot out lol. Hope my full front replacement bumper doesnt get in the way.
One more question, do you happen to know how much a clutch costs?
Old Apr 19, 2011 | 06:48 PM
BLADE35's Avatar
BLADE35
is your egr valve unplugged
Old Apr 19, 2011 | 07:03 PM
i eat hybrids
Egr valve plugged in!
Old Apr 19, 2011 | 07:31 PM
cheezit's Avatar
cheezit
the clutch is covered under 5/100
Old Apr 19, 2011 | 08:55 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Matt its not that hard to do 1-2 hours tops, even for you
Old Apr 20, 2011 | 10:19 AM
i eat hybrids
Cheezit, im outta my 5/100. But i did purchase a extended 2 year or 200k mile warrenty from ford.
And nick your an *** hahahaha. That post was prob cause your high on all that soot your modded deisels are pushin out.. BTW did you ever get your 450 back?
Old Apr 20, 2011 | 07:09 PM
cheezit's Avatar
cheezit
Im not sure on the 7/200 esp best to call and ask that one... I dont belive it is though
Old Apr 20, 2011 | 08:31 PM
i eat hybrids
Ya im going to. Gonna have to look at the wires first
James72work
Jun 6, 2015 10:52 PM
73fan
Jan 6, 2014 12:37 PM
540milotalon
Aug 15, 2012 11:08 PM
Special Ed
Oct 5, 2011 09:12 AM
ken324
Sep 29, 2010 07:08 PM
