ignition coil
Old Aug 1, 2008 | 02:20 PM
FORDMUDDER93's Avatar
FORDMUDDER93
ignition coil
on a 1979 f-150 with a 351m why am i getting about 13 to 14 volts to the ignition coil and how to fix it. that is when it is running
Old Aug 1, 2008 | 02:27 PM
fmc400's Avatar
fmc400
MSEE
Sounds like a previous owner redid the wiring. If this is the stock coil, you need to drop it down to 7-9 volts. The way this is done in the stock wiring is with a resistive wire that drops the voltage down. The primary winding of a stock ignition coil is on the order of 1 ohm, so it takes about 0.8 ohms in series upstream of the coil power to get you close to 8 volts. You can find a stock wiring harness in a junkyard, or even easier would be to get a stand-alone automotive grade resistor from a parts store. Old Chryslers used this setup and it's the easiest to retro-fit when a previous owner doesn't know what he's doing and thinks he can do a better job at wiring a vehicle. This is all assuming you are running the stock coil. Some performance aftermarket coils do take the full battery voltage.
Old Aug 1, 2008 | 02:40 PM
FORDMUDDER93
thanks i will try that.
Old Aug 2, 2008 | 06:13 PM
FORDMUDDER93
now that i got the voltage down the coil is still getting so hot that i can't touch it how can i stop that
Old Aug 2, 2008 | 06:19 PM
ford390gashog's Avatar
ford390gashog
Is the coil a stock unit or is it a aftermarket unit?
Old Aug 2, 2008 | 07:05 PM
FORDMUDDER93
it is a stock coil
cmazz811
Mar 26, 2014 08:49 AM
expguy121
Sep 6, 2012 07:38 PM
TexasGuy001
Oct 19, 2010 02:49 AM
rushinriver
15
Dec 17, 2007 10:49 PM
ford390gashog
Electrical Systems/Wiring
Oct 27, 2004 10:34 PM
