4 low
Old Jul 31, 2008 | 08:46 PM
water 5's Avatar
water 5
Question 4 low
my truck has 4x4 push on the fly system iam running AKC0 computer combo with 30 LB injectors and this set up will not let me use 4-low is there a way to buy pass this with some wiring to get 4-low
Old Aug 1, 2008 | 07:29 AM
Conanski's Avatar
Conanski
I don't think the computer has any control over the transfer case. You do need to be stopped with the tranny in neutral before engaging low range though.
Old Aug 1, 2008 | 08:15 AM
water 5's Avatar
water 5
on the haynes manual it does have tap #12 0n the pcm 4x4-L E4OD only witch goes to the switch system.
Old Aug 1, 2008 | 08:19 AM
Conanski's Avatar
Conanski
Interesting... I bet it's looking for neutral selection in tranny. You may have to tie this line to ground or 12v.. hard to know without seeing a schematic.
Old Aug 1, 2008 | 09:00 AM
jas88's Avatar
jas88
I have this setup in my Bronco and it is pretty sensitive to the MLPS switch adjustment. It is checking to make sure you are in neutral. If your MLPS is slopped out like mine is, you may have to choose between having reverse lights and having your 4-low work. I have to move my shift lever a bit to get my 4-low to engage, have you tried this?
Old Aug 1, 2008 | 06:56 PM
vols_fan22's Avatar
vols_fan22
After i got my tranny built my push button 4x4 low would not work and i never could figure it out so i swapped in a manual shift transfer case was pretty simple swap
Old Aug 3, 2008 | 09:14 PM
water 5's Avatar
water 5
no did't try that i l will look at that. trying to see if the in put to the pcm is a negative or positive input i need to look at the wire diagram.
Pockets52
Jun 22, 2013 08:45 PM
Bad 674x4
Mar 4, 2013 08:17 AM
bang4dabuck
17
Feb 3, 2009 11:03 PM
hammer65
Oct 6, 2008 08:26 PM
jonesy
Jul 24, 2002 02:54 PM
