true 4x4
Old Jul 31, 2008 | 09:41 AM
BobBarry's Avatar
BobBarry
Originally Posted by deereman4020
lockers for your rear axle(ford10.5in) can range from $300some(lockright)to $700(detroit) id go with lockright or detroit you dont have to worry about air lines and the are cheaper and simpler. a locker will lock all the time except when you turn on pavement
If you don't apply power while going around a corner, then the automatic lockers (Lockrite, Detroit, etc) will remain unlocked and allow the wheels to turn at different speeds.
If you apply power, they lock up and one will want to slip on the pavement; not really an issue with a rear locker, but it affects turning ability with a front locker.
Of course, on the street, you're never running in 4wd on dry pavement, so an automatic front locker will never come into play and for all practical purposes be invisible. If you put it into 4x4 in the snow, though, the locker will increase the slide of the front end when you get on the gas, so 4x4 becomes practical only at low speeds in deeeeep snow.
Old Jul 31, 2008 | 09:47 AM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
This sounds like what I had done in 1975. I had money then and just didn't care. I dropped if off at the shop and told them I wanted all 4 working off-road, but still be streetable. Sounds like you ain't gonna get that done for a grand anymore though. Thats the same truck I rolled down the San Gabriel Canyon and the insurance company wanted to total and I made them fix it. It sure worked good though as long as I could keep the shiny side up.
Old Jul 31, 2008 | 09:59 AM
HKusp's Avatar
HKusp
Here ya go mark. Check these out. They are nice. One of the many things I like to put on my "list".
ARB Air Lockers & Accessories | ARB 4x4 Accessories » Products »
Old Jul 31, 2008 | 11:31 AM
jwhitetail's Avatar
jwhitetail
NASCAR runs Detroit lockers, there great. but if i was to put anything in the front diff it would be True Trac. Also in the rear it makes anything handle the road wet or dry.
Jzinkiewicz
Nov 25, 2008 07:57 PM
papajoemrt
Exhaust Systems
23
Nov 13, 2007 10:25 PM
ZADOK
1983 - 2012 Ranger & B-Series
Jun 5, 2004 11:16 PM
MrF150
2004 - 2008 F150
40
May 12, 2004 10:40 AM
