winch wiring
Old Jul 29, 2008 | 11:51 AM
SPRPRBGT's Avatar
SPRPRBGT
winch wiring
i hope im in the right forum.
i have an '00 expedition with the factory wiring harness with brakes, etc. i want to put a winch on my ar trailer and i know there is a spot on the wiring that supplies 12v to the trailer. is there a fuse/relay for it that can handle powering the winch? it is a smaller winch but id like to avoid haveing a second plug
Old Jul 29, 2008 | 12:25 PM
Steina's Avatar
Steina
CO River Rat
That 12v pin is normally used to charge breakaway batteries and is hot only when the ignition key is on. Unless that winch's amp draw is VERY low, you'd be better off running a dedicated circuit - JMHO.
Steve
Old Jul 29, 2008 | 01:26 PM
grafekie's Avatar
grafekie
Definately run your own dedicated wire... winches draw WAY too much amperage. Your winch's manual should give you guidance on the gauge of the wire you need for that distance. The other thing you can do is run a seperate batter on the trailer, then run a charging wire to the battery from your truck's. That'll load a car onto a trailer, but it may not last very long!
Old Jul 29, 2008 | 02:03 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
I went with the second battery. Used a deepcycle marine battery. worked out really well. They take a lot of abuse and just charge it when you get home.
Old Jul 29, 2008 | 02:28 PM
SPRPRBGT's Avatar
SPRPRBGT
thanks guys. my buddy has wiriing to the back and front for a plow and spreader setup. then he uses the same one for the winch on his trailer. i didnt really want to do an extra plug.
if i put a battery on the trailer will the alternator keep up with the battery for the break away and for the winch?
Old Jul 30, 2008 | 07:30 AM
grafekie's Avatar
grafekie
If you drive the trailer enough, yes... or you could get a trickle charger, which would be a better idea.
phydeauxman
All Things Towing
13
Jun 2, 2020 03:49 PM
sand1
Sep 10, 2014 04:27 AM
JIMRSX
Apr 5, 2008 02:16 PM
QwkTrip
All Things Towing
Jun 15, 2007 09:25 PM
LxMan1
Offroad & 4x4
Mar 11, 2007 12:03 AM
