Hey everybody. I have installed a 7500lb winch on my car trailer. I have the Superwinch wiring harness for the truck that runs from the battery to the back with quick disconnects. What I am looking for is a good heavy duty circuit breaker to go between the battery and harness. It should probably be at least 200 amps. I want to protect the truck in case a wire were to go to ground. Where can I get one? The winch websites do have any that I could find.
Thanks,
Jimmy
i am no electrician by ANY means but i bet you could use a standard household breaker. also try marine supply places, they usually sell 12/24 volt breakers and other cool electrical gadgets
