I am thinking of getting some UPFITTER switches added to my '08. Is it just a quick install or do you have to do a bunch of wiring. I've called a souple service departments and neither exactly know what is going on.
Also. Once connected, Do you wire your accessories to the back of the switches or somewhere under the hood?
Very simple installation. If you buy the kit it comes with everything you need. I did this on my 2006 and only took an hour or so. The 2008 is nearly the same procedure. Check out the 2 links here for more information.
Thank you in advance.
I have these switches installed on my 06 PSD. Not sure what to use them for yet. What do you want to wire up to your switches? (Looking for ideas here).
On my 06 I had aux reverse lights, CB radio, and High idle mod. On the 08 I only have the aux reverse lights and a connection to an aux light to my trailer so far. Havent found a good spot for the cb yet but that will get hard wired when I do.
also u can get your fast idle through ure switches. only a idiot dealer or indiviual would order a veacle without this option or the trailer brake controll. they are dirt cheap if u get from the factory.
