351m roller
Old Jul 28, 2008 | 11:08 PM
92ranger's Avatar
92ranger
351m roller
how hard is it to swap over to a roller rocker setup on my 351m and if i do it what kind of performance changes can i accept. basically i wanna know if it is worth it.
Old Jul 28, 2008 | 11:38 PM
85e150's Avatar
85e150
Wrong forum. You need the 335 forums for the 351m.
To change to roller, find a cam supplier and buy their set up. 351m never had roller anything stock, so there are no stock parts awaiting liberation at the scrappy....
Old Jul 29, 2008 | 12:48 AM
rancheronut's Avatar
rancheronut
well the aftermarket makes a roller cam conversion kit for a 351Cleveland .so that will bolt into your 351m. i think crane is the name of the manufacture? check summit racing for it. it a smaller base cam ,so it will bolt inplace of your lifters and cam. the lifters have a plate that connect two lifter together to keep them from rotating. you can reuse your push rods. but the last time i check it was around$450.00 for the kit .goodluck.
Old Jul 29, 2008 | 08:08 AM
Conanski's Avatar
Conanski
If you swap to a set with a higher ratio you will gain some performance because the valves open further and the motor will move more air. These are pretty easy to install and not too expensive, the power gains are not hugh though.
david00f150
Mar 31, 2021 02:00 PM
CATM1
Jun 24, 2013 08:24 PM
Show-N-Go LX
32
Nov 29, 2005 10:59 AM
termyt00
15
Jun 20, 2005 07:02 AM
dbc
May 4, 2003 10:53 PM
