Speed Density Limits
Old Jul 28, 2008 | 06:37 PM
jburke832's Avatar
jburke832
Need some advice from Conanski here!
I am fast approaching the end of my rework of a '90 EFI 460 for my '89 F-250 4X4 C6 transmission and am starting to worry if I have built beyond the limits of what my speed density ECM can do for the new engine.
The new engine is a .040 overbore with TRW flat top pistons, stage 2 ported heads, MTF towing cam (204/214 @ .050), Borla headers with true dual exhaust with X pipe and high perf mufflers (no catalytic, air pump, or EGR), BBK twin 65 MM throttle body, and K&N air filter. I am estimating a 10:1 compression ratio and around 375-400 HP. I suspect I will need to replace the 24# injectors with 30 pounders.
I'll be hooking it up to a '96 E4OD using a TCS Baummantor box.
Have I exceeded my Speed Density ECM? I am planning on moving to MAF but would like to get it up and running on the existing ECM if possible (I really don't want compound initial start up issues with the MAF conversion if I can avoid it.)
Any advice would be appreciated on the speed density ECM, injector sizing, compression, or horse power estimate.
Old Jul 28, 2008 | 08:46 PM
Raider50's Avatar
Raider50
cant help much but i would feel bad if i didnt tell you it sounds awsome and i wished i could do that . The thing that would make me think it would work is that if you can supercharge a speed density 460 and not have any problems you should be fine. Also did you think of bigger fuel pumps and/or a fuel pressure regulator?
Old Jul 28, 2008 | 08:55 PM
jburke832's Avatar
jburke832
To the best of knowledge, the stock fuel pumps and pressure regulator should handle the mods.
If I am wrong, please advise!
Old Jul 28, 2008 | 09:37 PM
Raider50's Avatar
Raider50
I was thinking to get new ones because if i remember right a guy clamed a night and day difference and his motor wasnt as modded as this guys, i think they kind of just cram in fuel, but your right i think the stock ones should work fine.
Old Aug 11, 2008 | 10:01 PM
vskidmoreii's Avatar
vskidmoreii
hey Burke,
How did your engine turn out? Does it run ok or did you end up having to install the MAF system? Just wanted to check because I am thinking of doing exactly what you mention here.....
Old Aug 11, 2008 | 11:29 PM
jburke832's Avatar
jburke832
Thanks for asking, but it is still a work in progress. I have the block and all of the ancillary parts together. Waiting on the head work to be completed before I can drop it in.
I am currently replacing the dual 51 MM throttle body with a dual 65 MM BBK from an 02 Lightning.. I have pretty much decided to go MAF on start up. I will need to add 8 wires for the injectors, 2 for the MAF sensor and reposition a few others. If I run into problems I'll swap back to speed density pretty quick just to get it up and running.
I'm figuring about another month before I hit the starter on the new rig.
Old Aug 11, 2008 | 11:41 PM
vskidmoreii
Cool,
Another quick question - Are you having the stock heads reworked or did you decide to use other heads?
Old Aug 12, 2008 | 12:19 AM
jburke832's Avatar
jburke832
Been tryin to do it on a budget, so I'm having the stock heads reworked. If you go with after market heads, they are set up for carbs...match the older 460 intakes/exhaust. So, after market heads mean custom intakes, fuel rails, throttle bodies, etc for EFI. Big bucks. I'm not planning on NHRA championship runs, just a cool daily driver that should pull the front porch off of the house.
Old Aug 12, 2008 | 10:02 AM
stngh8r's Avatar
stngh8r
Thumbs up
I Love It! Please keep us informed on the progress. I hope you end up dynoing it, I'm quite curious what kinda torque this baby is going to make.
Old Aug 13, 2008 | 02:14 PM
leadmic's Avatar
leadmic
I was thinking of doing the same thing on my 97 factory MAS AIR 460 from Cali. Do you have the new throttle body bolted up yet? What mods did you have to do if any? T
Thanks for any help
Leadmic
octaneforce
May 9, 2013 10:07 AM
85lebaront2
WTB - Parts & other
May 2, 2012 01:02 PM
wreckless93
Jun 9, 2011 04:33 PM
beeturbo
Jan 25, 2010 07:51 AM
Redneckerson
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Oct 30, 2002 12:28 PM
