Need a Geek!
Old Jul 28, 2008 | 05:23 PM
Bill W's Avatar
Bill W
Need a Geek!
Today my computer was taken over by one of those buy me programs
AntivirusXP08 Exactly!
I cant for the life of me get it to GO AWAY!
Will not let me do a system restore or anything
It keeps poping up on the Screen bothering the heck out of me
HELP if you can. Thanks
Old Jul 28, 2008 | 05:35 PM
Virto's Avatar
Virto
Try grabbing Webroot's Spysweeper. They should still have a trial version that will get rid of it. Alternatively, Lavasoft's AdAware might work, but personally I find it less effective in practice.
Old Jul 28, 2008 | 05:36 PM
donjamer's Avatar
donjamer
Lets try a few things..
I am not sure what file is controlling this. so we can start with the simple first..
Has this happened in the last few days??
Have you tried running System restore to go back to a date before the infection?
Most of the time this will work if it hasn't been to long..
Old Jul 28, 2008 | 05:41 PM
donjamer's Avatar
donjamer
OOPs! just reread the OP and found you already tried restore..
What I would try is first install Superantispyware.. It is a free program that has worked for me on some customers PC's.
Next download and try running VUNDOFIX_dot_exe (replace _dot_ with.)
If you google it there it will be the first option.
I believe this is a Vundo variant that this program should remove.
Old Jul 28, 2008 | 05:49 PM
Bill W's Avatar
Bill W
Thanks I will try that.
Damn thing took over my Google tool bar also.... takes me to Womans day mag
Old Jul 28, 2008 | 06:09 PM
pitrow's Avatar
pitrow
First of all, don't restart the computer if you haven't already! That'll just make things get deeper into your system.
Here's my trifecta for cleaning a system:
AVG Antivirus (I think they still have a free version)
Spybot Search and Destroy
Lavasoft Adaware
Download all three of those and install them.
Then start by looking through your system configuration for anything odd. Do this by going to Start -> Run, then type msconfig in the box. Go to the startup tab and look for anything weird, or anything that doesn't have a name. Uncheck those items so they don't load at startup.
Then run each of the programs listed above to see what they turn up with. Use them to clean the system. Keep running those until they don't find anything else. Sometimes once they've cleared up one bug it'll uncover another.
Once they show clean, reboot your computer into safe mode (usually by hitting F8 while it's rebooting to get the system menu). In safe mode it won't load up a lot of the system stuff so things will look weird, but because lots of things aren't loaded that usually are, you can get things cleaner. Run the three again to make sure there's nothing lurking around.
Reboot as normal, and then make sure you have all the security updates installed on your computer. And run the programs one more time to double-check everything.
Hope that helps!
Old Jul 28, 2008 | 06:22 PM
Bill W's Avatar
Bill W
Don, I did both things superantispyware and vundofix, It took care of some thing I did not know about.... But it did not remove the XP08 stuff
? anything else I can try? Again Thanks, Bill
Mike Thanks, I have AVG, I will try the others also.
Old Jul 28, 2008 | 06:30 PM
donjamer's Avatar
donjamer
Try going into safe mode then run the scans again..
These things are pretty tough to get rid of..
One other program to try is smitfraudfix_dot_exe which is for this type of bug. Run this under safe mode also.
If that does not work download a program called combofix_dot_exe and run that in safe mode.. This program has a warning that data could be deleted, but I have never had a problem..
Old Jul 28, 2008 | 11:34 PM
Bill W's Avatar
Bill W
Thanks Don! and Mike and Virto!! Got rid of it! went to safe mode and did all the other things.... But I still had to redo my computer. Just put it back to factory specs... I lost some things, thats OK though, just a bunch of junk anyways saved my pic's to a disk first! worked Good for someone who knows nothing about puters
Again Thanks for all the Help!
Bill
Old Jul 29, 2008 | 10:23 AM
Virto's Avatar
Virto
Sorry we didn't get it without a wipe. They can be real buggers sometimes, and no matter how much experience people have working on cases like this, it's always harder to diagnose and resolve without the machine in front of us.
Glad to know you're back up and clean, hope you didn't lose too much.
Old Jul 29, 2008 | 11:03 AM
donjamer's Avatar
donjamer
Bill,
Good to see your back up and running..
I was waiting for you to reply after trying the last options.. I was going to offer to have you call me and I could have walked you deleting the files..
It is probably better that you did the factory restore, because sometimes you think you have then cleaned out, but they come back after rebooting a few times..
Don't forget to install a spyware blocker like Spybot so you remain clean..
I recommend spybot and spywareblaster... Both are free/Donation ware programs that work great together..
Old Jul 29, 2008 | 01:09 PM
jake00's Avatar
jake00
saves ya the time searching for it.....
F350-6
20
Jan 1, 2008 04:41 PM
FLYBOY07
Nov 25, 2007 01:51 PM
FORD352V8
Oct 21, 2004 05:02 PM
Cirdan49
34
Oct 15, 2004 08:06 AM
F2504x4
23
Jun 13, 2004 05:01 PM
