need a little Pc help
Old Nov 25, 2007 | 02:09 AM
FLYBOY07's Avatar
FLYBOY07
Thumbs down need a little Pc help
what is causing my Compaq laptop screen to go blank when loading up windows normally. Everything works fine up until windows finally loads up it even lets me put in the password then the welcome screen comes up shoes my background then the screen just goes black for no reason . and will not recover. but it appears windows is still functioning everything still works but the screen. I'm using it now it WILL operate in Safe mode with networking. its' working great now but as soon as i go back to normal operation the problems begin.. Any help would be appreciated as this pc is less than 4 months old. I promise to God the moment i can get rid of this windows Vista garbage It'll be as good as gone. Thanks for your help
Old Nov 25, 2007 | 07:28 AM
mistakenID's Avatar
mistakenID
Sounds like you may have a virus. After booting normally while at the black screen, you can try to start explorer***** from start/run or from task manager. If the screen comes up and then goes back to black, you have a virus. FYI-the keyboard combination Windows Logo+R (Open the Run dialog box) CTRL+ESC (Display the Start menu)
http://support.microsoft.com/kb/301583 list of keyboard shortcuts, useful at times
Try running a couple online scans from http://housecall.trendmicro.com/ and http://www.kaspersky.com/virusscanner
Old Nov 25, 2007 | 10:44 AM
donjamer's Avatar
donjamer
What do you have your screen resolution and refresh rate set at?
Try changing the screen resolution and refresh rate to something lower.. I have seen this happen when the refresh rate is not compatible with the display.
Also did this just happen on its own in the last few days?
You might want to try a system restore back a few days to see if that fixes it.
Old Nov 25, 2007 | 01:51 PM
FLYBOY07's Avatar
FLYBOY07
Smile
Ah yes the old restore trick, forgot all about that one.. Well it worked and everything is working again fine. Thanks for your help guys
cjben
16
Oct 30, 2011 08:21 AM
F350-6
20
Jan 1, 2008 04:41 PM
cjben
17
Sep 9, 2007 05:27 PM
I6power
Jun 6, 2006 03:27 PM
bodabdan
Nov 30, 2005 08:41 AM
