cluster problems on a 2000 ranger
Old Jul 27, 2008 | 05:56 PM
black_ranger730's Avatar
black_ranger730
Question cluster problems on a 2000 ranger
i have a few problems on my 2000 ranger 3.0 one of them is the speedometer even on neutral just engine idling speed is already up to 15mph second is the oil gauge pressure is always pass H.. how do i fix this? also where can i get my rcm reset coz its reading a code 19..can someone please help me im new to this forum
Old Jul 28, 2008 | 07:48 AM
pawpaw's Avatar
pawpaw
Welcome to FTE.
You may have two, or three separate problems, but we'll need more info to know for shure.
Did these two problems come about suddenly, at the same time, after some event, or separately over time????
The Rangers oil pressure meter is not much more than an idiot gauge, as it's designed to read mid scale when we have about 7 psi oil pressure.
So with your gauge pegged at full scale, maybe suspect a short circuit on the wire going to the oil pressure sending unit, or the sending unit itself, which is on the engine.
The speed-o is not cable operated, but is electonic & uses signals from the rear ABS speed sensor, located atop the front center portion of the rear differential.
So if you aren't having other electical problems, maybe suspect the rear ABS speed sensor, or it's wiring to the speed-o.
If your having other electrical gremlins with other things, then maybe the instrument cluster is being affected by that, so we need more background info on your ride.
Just some thoughts to help us get started on your trouble shoot.
Old Jul 28, 2008 | 08:47 AM
black_ranger730
thanks for the reply, i bought the car used/salvage and the previous owner always had it like that never bothered checking it, it was in an accident and got it fix then he had it for two years like that, i was actually just thinking of swapping it with a cluster that has a tach like from a explorer if its possible thinking it could fix it to or should i check all those things that you told me to check before doing a swap? don't have any other electrical issues except for those, and for the cluster swap is it just plug n play?and for my rcm were can i get it reset? thanks for all the help, appreciate it...
Old Jul 28, 2008 | 10:21 AM
pawpaw's Avatar
pawpaw
Dang I forgot the code question. Are you certain on the code 19????
Your 2000 Ranger is OBD-2, so it should have 3 digit PXXX codes, a two digit code like the 19, is for older OBD-1 vehicles, so I'm not clear at this point just what your computer is trying to tell us hurts.
Most auto parts stores will scan the computer at no cost & can clear any codes, but if you haven't fixed the problem, it'll return.
You can also erase the code by removing the B- battery cable, or pulling the computers power fuse, for 20 minutes or so.
Seeing as how the vehicle has been wrecked & repaired/salvaged, who knows what kind of electrical or mechanical trauma it's been through, so it'll kinda complicate your trouble shoot imo, as you'll have to include all kinds of other possibilities that wouldn't normally apply to a well maintained, non accident vehicle.
Right now it's probally easier for you to just disconnect the lead at the oil pressure sending unit & see if the oil pressure gauge will stop slamming full scale. If so, then suspect the sending unit.
If not, suspect the wire is shorted, or the gauge or instrument cluster is bad.
I believe I've read that a Ranger cluster with tach is a plug & play, but I'm not sure about which Explorer model cluster your referring too.
Old Jul 28, 2008 | 03:10 PM
black_ranger730
a code 19 is an airbag code i counted it 1 pause and 9 contnuous blinks and happens like 5 times and thats how i called it a code 19 here is that post where i found out what it is https://www.ford-trucks.com/forums/3...code-19-a.html
for the pressure sending unit where exactly is that on the engine? for the cluster with tach what is truck is compatible on mine? thanks again..
Old Jul 28, 2008 | 03:33 PM
pawpaw's Avatar
pawpaw
I'm kinda slow today, after re-reading your initial post I now realize you were reading your airbag warning light, not the Check Engine Light!!!!
I'm a 4.0L guy, so I don't remember exactly which side of the engine a 3.0L's OP sending unit is, but it's likely close to the oil filter. Try a site search for 3.0L oil pressure sendng unit, I know this has been discussed in the past 12 months.
Or maybe try AutoZones parts locator.
Or maybe one of the 3.0L guys will chime in.
Let us know what you find.
Old Jul 28, 2008 | 09:11 PM
black_ranger730
cool thanks, let me know if you find it first though...
wally32
44
Apr 9, 2016 03:12 PM
frogmanc1
New Member Introductions
Oct 14, 2013 01:19 PM
ReBilld
Mar 17, 2012 04:18 PM
Ranger8539
15
Nov 14, 2010 07:18 PM
Phrog Driver
Feb 21, 2004 09:38 PM
