last header question
Old Jul 27, 2008 | 12:19 AM
HighdefJoe's Avatar
HighdefJoe
The 331 I'm putting in my 86 2wd has ported and milled GT40 iron heads, 1.6 Crane rockers, and a stage 1 Trickflow cam with .499"/.510" lift. The headers I was going to order were the Flowtech 12502flt, (the Hooker 6907hkr's are back ordered until late august).. anyway, do you think it'd be a huge power loss if I stepped down from the mustang 1 5/8" BBK longtubes
to the 1.5" truck headers? Are there 1-5/8" truck longtubes that aren't over $350?
Old Jul 27, 2008 | 12:53 PM
Franklin2's Avatar
Franklin2
What transmission and rearend gears are you going to run? And if an automatic, will you have a stall convertor? If you never turn the higher rpms, then the larger header size won't matter.
Old Jul 27, 2008 | 03:51 PM
HighdefJoe's Avatar
HighdefJoe
The transmission is a 4spd OD manual. I'm probably going to need to find a 5sp ZF tranny after the motor swap. As for gearing, I have no idea what the truck has now. If I feel it to weak, I'll gear it later. Either way, I won't be revving too high anyway. It's my daily driver. When the engine was in the mustang, I would race it all the time but I just want a good motor for the truck while I build the monster for the mustang
Old Jul 27, 2008 | 10:23 PM
Franklin2's Avatar
Franklin2
I would think the smaller headers would be ok. I would not go too wild with this motor if you are going to keep the rpms low. A truck is heavier than a mustang, so a high strung high revving engine is not going to work very well in the heavier truck unless you change the gearing. You will know right away if you are out of the powerband when in OD because the engine will not have hardly any power down in the low rpms.
Old Jul 28, 2008 | 08:00 AM
HighdefJoe's Avatar
HighdefJoe
Thanks Franklin. I'll let you know how it ends up when i finish it!
Old Jul 28, 2008 | 11:03 AM
nflfreak43's Avatar
nflfreak43
i want to see a video of this truck in action when your done this truck sounds like it will GET UP AND GO!! at least you wont have to worry about if you have power when you need it
danger-ranger93
Mar 24, 2010 04:30 PM
70torino429
Oct 30, 2009 10:56 AM
bbf150
Sep 5, 2009 04:22 AM
paintslinga2010
Mar 26, 2009 10:45 PM
78bigunns
Oct 23, 2007 11:49 AM
