CB antena
Old May 6, 2002 | 04:41 PM
Mil1ion's Avatar
Mil1ion
CB antena
That's correct.
I would think a Magnetic Mount on the roof would be okay.
Make sure the *load* of the antenna is above the ground plane.
A 102 " whip is okay.Make sure you have a tie-down clip for the antenna for allowing you to get into parkades.
Just remember the strongest signal goes the longest part of the ground plane.
If the whip is mounted on the back ,the best signal goes out the front & vice-versa.
Talking distance is usually *LINE OF SIGHT*, 15-18 miles unless you're in the mountains or abnormal conditions.
[b][i][font color=red]Dennis[/font][i][b]
[font color=red]Calgary,Alberta,Canada[/font]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=green]Do You Need To Decode Your 78 Truck Data Plate?
[/font
http://www.clubfte.com/users/mil1ion/FordTruckCodes.html
[font color=red]If New Ford Parts Is What You're Cravin',
Then Buy Them HERE,At Motorhaven![/font]
[font color=green]Please Feel Free To Visit My Website.[/font]
http://www.clubfte.com/users/mil1ion/Mil1ion.html
[font color=red]
Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [/font]
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V [/font]
Old May 6, 2002 | 06:58 PM
MustangGT221's Avatar
MustangGT221
CB antena
Well, if anything i'd mount two whips in the rear stake pockets, not the ones behind the cab. I think this looks the best unless you have good mirrors. The wires can even go neatly down the hole beside the stake pocket. I wouldn't care if only one antenna works, the others gotta be there for symmetry. I'm not interested in the best cd system out there either. Where have you guys mounted the Radio in ur cabs?
Primary rig is:
95' F-150 EB 300/6 5 spd with 4" Superlift, MSD, Ram Air, Gibson Exhaust, 32" BFG Muds
THERE ARE SOME PICS IN MY GALLERY!! :-)
Then theres:
88' F-250 Superduty 351 + c6
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 and a
3 spd column shifter. Top speed, 65mph, Go Baby Go!
The newest addition to the Ford family is a 99' Mustang GT 4.6L
Old May 6, 2002 | 09:03 PM
Mil1ion's Avatar
Mil1ion
CB antena
I bought an Adjustable floor mount and installed it on the hump just barely under the dash.
For in-depth technical Information have you done a search on google by typing " CB Radio Installation " ?
[/font
[font color=red]
Old May 20, 2002 | 09:14 AM
Peg Leg's Avatar
Peg Leg
CB antena
Anybody have a problem with their CB and engine noise on their F-150? I am using a Cobra 29 with a Wilson 1000 magnetic mount antenna. I have tried several wiring options, cig lighter, direct to fuse block on + and to a ground with the - lead, but still get a high pitched noise with the engine running. I have tried several noise chokes on the power leads but still have the noise.
HELP! Anybody else have this problem? Any ideas on the solution.
Any suggestions would be greatly appreciated.
Thanks!
Peg Leg
Old May 20, 2002 | 02:55 PM
MustangGT221
CB antena
I could be wrong but it could be the kind of spark plugs you are using. I know that with the helmet comunicators on my snowmobiles, you need to have a certain kind of plug.
Primary rig is NOW TOTALLED :-X23 :
Some pictures in my gallery.
Then theres:
Old May 21, 2002 | 01:54 AM
Mil1ion's Avatar
Mil1ion
CB antena
A popping sound that changes with the rpm of the motor is ignition pop.
A high pitched whine is from the Charging circuit,namely the alternator.
[link:www.ford-trucks.com/guidelines.html|FTE Moderator]
[font color=green] Truck Data Plate Info
[/font
[font color=red]
[/font]
Old May 21, 2002 | 07:52 AM
Peg Leg's Avatar
Peg Leg
CB antena
Think I found the answer to my problem on Wilson Antenna's web site, although, what a Pain in the A_S!
4. Vehicles with electric fuel pumps in gas tank
Although this is not aimed at any specific auto, primarily it is noticed with the Ford and Toyota autos, with the electric fuel pump located inside the gasoline tank. The symptoms are: a noise (generally a whine or whistle) is very noticeable on the radio when the ignition is first turned on, stopping after a few seconds. It returns when the auto is started and continues as long as the engine is running. The cure: install a pair of RF filters, one on each of the leads (positive and negative) coming out of the fuel pump. CAUTION: Be sure to check the vehicle maintenance manual to get the correct wires, and not the fuel level indicator wires. We have found the best available filter for this is the LM-20RF, from MTI, in Signal Hill, California, (800) 772-0796. They manufacture a wide array of filters to solve radio interference problems.
Anybody know which wires are the power wires on the fuel pump of a 2001 F-150 Super Crew with a 5.4L? What a pain in the A_S!
Thanks!
Peg Leg
Old Jul 16, 2002 | 09:44 AM
BigMick_97_Expy's Avatar
BigMick_97_Expy
CB antena
Sorry to bring this tread up agian, but I've got the same problem form my 97 Expy. I installed the CB and I've got a loud whine coming from the speaker... did you ever figure out/get it fixed?
Thanks
Big Mick
1997 Expedition XLT
K&N Air Intake
Hellwig Anti sway bar
Flow master
Plus extra mods.....
Old Jul 16, 2002 | 12:04 PM
Mil1ion's Avatar
Mil1ion
CB antena
A whine is from the charging system.
Noise is solved by installing a noise choke available at The Shack.
A popping noise is from the Ignition system.
This noise can be removed by a special filter/choke on the ignition system at the coil available at The Shack.
FTE Adminstration
[/font]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
64 1/2 Mustang Pre-World's Fair Car #8092
68-Mustang 289 2v-Sunlit Gold
[/font]
Old Sep 9, 2002 | 05:35 PM
JScott488's Avatar
JScott488
CB antena
I'm 19 years old, and have been into C.B.'s and FORDS since I was 7. As someone said earlier, having two live antennas is useless, but two sometimes looks better than one..And he was right, run one live antenna, and the other as a dummy. Co-phase coax is a pain to run on a pickup anyway...lol.. I have a uniden PC68XL, peaked and tuned. I mounted it to my headliner angled slightly toward the driver's side. I ran my coax under the trim to the holes in the bottom of my cab, and up to the bed rail corner, drivers side. Drilled two holes, mounted bracket (bed is a good ground) and put on a cheap fiberglass whip. Works pretty darn good. I've talked up to 45 miles on the setup. BUT, nothing is ever good enough, right? Anyone know where I can get a mobile linear? I've been lookin for one for a long time!
1995 F-150 XLT 4x4 302 AODE, 31X10X50 Goodyear
Old Sep 9, 2002 | 06:10 PM
tinman211's Avatar
tinman211
CB antena
One of the best mounting locations for that antenna is near the center of that cab roof. Some people use a good mag mount if they don't want to drill a 3/4" hole and install a nmo mount. Me personally i don't have the cb antenna mounted there because i have others in that location. for the cb antenna I use a 102' stainless whip mounted on the right rear bumper with antenna specialist hardware but radio shack has everything you need also. Just use the best quality coax and connectors. I might note that i don't experience any of the fuel pump whine or ignition noises. As far as cb i wouldn't go any further and waste my money as far as amps. there is so much out there in the communcations area that 45 miles is just a stones throw when we are speaking world wide legally. Just explore sites such as ARRL and QRZ.com and learn and enjoy
Have a Good Day
Janos
Old Oct 17, 2002 | 02:58 AM
JScott488's Avatar
JScott488
CB antena
[updated:LAST EDITED ON 17-Oct-02 AT 03:58 AM (EST)]I visit QRZ.com and ARRL.com frequently. Got my HAM License 4 years ago.(KC0DED) I enjoy it very much. BUT, playing with C.B.s is alot of fun too...HAMMER DOWN!
Jon kc0ded
1992 Ford Tempo 5spd 2.3
Old Oct 17, 2002 | 11:01 PM
  #28
sparky's Avatar
sparky
CB antena
2015F350
6.7L Power Stroke Diesel
Aug 17, 2015 03:23 PM
mndiesel
Dec 2, 2011 08:44 AM
46yblock
May 22, 2006 02:36 PM
supercab78
16
Nov 6, 2003 12:48 PM
