door panel vibration
Old Jul 26, 2008 | 09:36 PM
1985 Ford F-150's Avatar
1985 Ford F-150
I just put some door panels on my truck that came off of the 75 parts truck I have. They are held on by the factory clips didnt break anything when I pulled em off the other truck. They fit good and stay where thyere supposed to be, but they just rattle when i turn on my radio i dont even have that much bass either. How do I fix this its really anoyin when all you hear is rattlein?
Old Jul 26, 2008 | 09:51 PM
jason867's Avatar
jason867
Get a can of silicone and apply some on the inside of the door panel where you think it's rattling at. Let it dry for a day and see if that fixes it.
I just came up with this but I think it would work.
[edit] Not silicone lubricant spray, the silicone goo in a can that drys solid but rubbery flexible... Useful for many things!
Old Jul 26, 2008 | 09:57 PM
BrentNewland's Avatar
BrentNewland
If you don't want to apply foam to anything, you might try some shims taped in place.
Old Jul 26, 2008 | 11:44 PM
fmc400's Avatar
fmc400
MSEE
You might not have them snapped in all the way in some spots. You can also replace the plastic snap pins, as they are fairly soft and the ridges can wear away when they've been installed\removed a few times.
Old Jul 27, 2008 | 10:51 AM
1985 Ford F-150
Thanks guys i really dont want to put silicone on the door cause i wouldnt ever be able to get the panel off. The clips are the metal ones not the plastic ones that are on the door pouches. What do I make the shims out of.
Old Jul 27, 2008 | 11:37 AM
OldMetal's Avatar
OldMetal
If all else fails try some of that stick on weather stripping to take up any space, you can get it at any hardware store.
Old Jul 27, 2008 | 01:02 PM
jason867's Avatar
jason867
Well the silicone I use will peel right off with little to no effort...
Old Jul 27, 2008 | 01:37 PM
1985 Ford F-150
Where do I get that kind of silicone the stuff i use is rtv and permatex
Old Jul 27, 2008 | 07:48 PM
4x4 Bart's Avatar
4x4 Bart
use a sheet of one quarter inch foam, trim to size, glue one side to door.
Old Jul 27, 2008 | 07:56 PM
1985 Ford F-150
Ok i have another set of brown door panels that have some sound deadener on em would this work.
400inatruck
Jul 11, 2012 01:28 AM
chicagodragon
Apr 16, 2010 10:50 AM
terceslil
17
Mar 26, 2010 08:50 AM
TCinNH
1997 - 2003 F150
Mar 12, 2006 09:24 PM
grey169
Mar 16, 2003 05:07 PM
