Supercab moveable window hinge pins
Old Jul 26, 2008 | 06:20 PM
Behemoth's Avatar
Behemoth
Ok, I was moving along at a pretty good clip today when I ran directly into a brick wall.
I have my moveable quarter windows back from the tinter, I have the latch bolts back from the powdercoater, I have brand spankin new hinge cups that pop into the body, and I even found a couple of the plastic washers that insulate the window from the latch bolt...however...where in the heck can I find a set of the hinge pins that go inside the hinge cups?
I can already tell that these are necessary, otherwise the windows will pull out too easily. If anyone can lead me in the right direction on this one, I'd appreciate it.
Old Jul 27, 2008 | 06:10 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Hinge cup...what the heck is that?
Without you seeing the parts catalog diagram, it's hard for me to determine what you want.
On the front side there are two rectangular shaped quarter window hinge retainers (D5FZ73302A12A) that pins (385350S) fit into.
These are the exact same parts that the 1973/80 Pinto/Bobcat station wagons used on its quarter windows.
Then there are quarter window latch pins (DODZ6230330A -1/2" long) or (DODZ6230330B -3/4" long).
These latch pins are the same as 1970/77 Maverick/Comet 2 door / 1974/78 Mustang II Fastback / 1971/80 Pinto 2 door sedans used on their quarter windows.
greensalescompany.com has 10 each of either length in stock: 800-543-4959
Old Jul 27, 2008 | 09:43 AM
Behemoth's Avatar
Behemoth
OK, ok, ok...yes, I'm talking about the plastic hinge retainers that press into the slots on the exterior of the cab. I know, I wasn't using the proper Ford terminology, but was "hinge cup" really that far of a logical leap to determine that that was what I was referring to? (Although the more I say "hinge cup", the weirder it sounds)
Anyway, yes, you're right. I'm speaking about the hinge retainers and the associated pins. You didn't say if Greensalescompany had any of the 385350S pins in stock...I'll give them a call on Monday to find out.
As always, thanks for the assist.
Old Jul 27, 2008 | 08:19 PM
NumberDummy
Green doesn't have the pins (385350S).
Old Jul 27, 2008 | 09:08 PM
Behemoth's Avatar
Behemoth
Wellllll, that puts a damper in my day...guess I'm going to have to improvise a solution. Should be easy enough with either a proper diameter nail or piece of steel rod, my dremel, and a cutoff wheel.
Thanks for checking.
Old Jul 28, 2008 | 01:30 AM
NumberDummy
Dunno how many Pinto wagons there might be in junkyards, but the pins are the same...
Old Jul 28, 2008 | 07:46 AM
Behemoth's Avatar
Behemoth
That'd be a big 'ol goose egg...with the price of metal these days, most yards are crushing any cars that are older than 10 years for the cash. I haven't seen a pinto wagon in a yard in a lonnnnnnnnnnnng time. Hell, even at the yard I go to most, they only have one 73-79 truck on the lot. Pretty much everything else is 95 and newer. I did, however, luck out and found a 90 Ford Econoline van at a different yard, that had the pop out windows. The latch mechanisms are different, but the plastic washers that insulate the bolt from the glass itself are the same as my 79...so I used those. Worked like a champ.
I'll figure out a pin replacement...just will take some snooping at the hardware store.
Old Jul 28, 2008 | 08:12 AM
NumberDummy
FOUND 385350S = Green Sales does have them: 800-543-4959
I typed that part number into their website two days ago, it showed zero, so I called them a few minutes ago to ask them to run the number on an obsolete parts website I don't have access to.
The nice lady said...we have them.
Old Jul 28, 2008 | 11:41 AM
Behemoth's Avatar
Behemoth
Numberdummy, you are, as always, a veritable wellspring of useful information...I'll call them today. Thanks again.
Old Oct 8, 2019 | 07:40 AM
alans77crew's Avatar
alans77crew
GREEN SALES NO LONGER HAS
well just to get i out there they no longer have the hinge pins for the super cab quarter window! Damn the bad luck!!!
Old Oct 9, 2019 | 01:20 AM
NumberDummy
Just because Green Sales doesn't have them, doesn't mean that no one else does.
385350-S =
KLIMESH MOTOR SALES in Calmar IA has 12 = 563-562-3241.
NOS PARTS LTD in Waxahachie TX has 16 = 972-937-2201.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 27 = 800-476-9653.
Old Oct 20, 2019 | 09:22 AM
alans77crew
You are right sir! just bought a package of 20 from henry's parts depot figured I might as well buy all of them.Carpenter told me they didn't have any, when i bought my hinges about 2 to 3 weeks ago! but again as always your here to save the day!!!! many thanks for your expertise
Maryrylee
58
Jan 13, 2022 09:31 PM
Jeff Mock
27
Sep 11, 2019 04:08 PM
hhight
Jul 29, 2014 06:08 PM
Lindemanlax
Jun 7, 2014 02:06 AM
chefcharles
Feb 15, 2014 09:49 PM
