1966 f100. Window regulator
I've been searching for a window regulator and inside door handle shaft assembly for my 66 f 100 ,LMC ,Macs and Dennis Carpenter all list them as out of stock and not available. I imagine the next step is searching junk yards ?but don't imagine there's a lot of usable parts here in New England ,even IF I could find "parts truck" in a yard.
I did respond to someone on this site advertising the parts but never got a response to my PM ,so I probably didn't send it properly ?? Not very good at the computer communication maze. Help?
May
May
1961/66 F100/1100 / 1963/69 N/NT/T500/1100 / 1967/69 F800/1000:
C1TB-8121818-B .. Door Lock Remote Control Assy - Right/Left same / Obsolete
KAMA OBSOLETE PARTS in East Bethel MN has 1 = 763-434-0123.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 3 = 800-476-9653.
C1TZ-8123200-B .. RIGHT (Passenger) Side Window Regulator / Obsolete ~ 23 available NOS
C1TZ-8123201-B .. LEFT (Drivers) Side Window Regulator / Obsolete ~ 2 available NOS
I'll list the sources as soon as I know which side you need.
And, are you sure the window regulator is defective?
Look at this (right side) parts catalog pic for 23240 .. this is the nylon window roller that attaches the regulator (23200) to the window channel (21458).
The roller breaks, the window binds up or falls down into the door.
Window regulator ?
Thank you both for your reply
Number Dummy , The window regulator is for the left side(drivers side) door
I don't think the regulator is defective but the spindle or shaft that the window crank attaches to is stripped beyond use . It looks like that is not seperate from the whole regulator mechanism?? I was hoping that I could just replace the spindle but not so....
Excuse my ignorance but In the list of parts numbers and sources that you've supplied what does NOS stand for?
Again when I went online to Dennis Carpenter site the parts were listed as out of stock and not available . I hadn't gotten around to calling directly yet .
The shaft or spindle for both inside door handles are also stripped so I need to replace both those .
Shoo, I am also going to have to replace all the window channels ,trim etc so depending on cost of freight,and condition of parts the whole door MIGHT be an option?
I will also get hold of Squire Don now that I have his contact info.
Thank You all
May
Thank You all
May
They're listed on his obsolete parts webpage that's a confusing PITA to use. Thankfully, the parts are also listed on PartsVoice.com, where I got the info from.
Look at the parts catalog pic and you'll see that the shafts that the splines of the inside door and window crank handles attach to are not available by themselves.
