Modular V10 (6.8l)
Service Engine soon light :(
Old Jul 26, 2008 | 01:06 PM
shlby123's Avatar
shlby123
Only had my truck a week and half and the service engine soon light popped on. I'm scared to even take it to the dealer. It runs fine, shifts great, runs great, no visible issues whatsoever. The truck only has barely 74K on it. Ya'll know anything I can check on to start off with before I take it to the dealership to most likely get raped this afternoon? I do believe I can run codes on it if I can find the OBDII port because I have a diagnostics X-Ray scanner...What do the V10 gods think?
Old Jul 26, 2008 | 06:56 PM
hydro_37's Avatar
hydro_37
Take it to an auto parts store. They will scan it for free and you can see where the scan port is and what they do to pull the code or codes.
Old Jul 26, 2008 | 08:33 PM
projectSHO89's Avatar
projectSHO89
By federal law, the port must be within either 18 or 24 inches of the steering column (or something like that).
Just look for it.
Steve
Old Jul 26, 2008 | 10:10 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
What year is the truck?
My '01's port is under the steering column, about 6-8 inches to the right.
If your scanner is an OBD-II scanner, you should be able to pull the codes yourself.
Report back with the codes, we'll work on it
Old Jul 27, 2008 | 12:45 PM
shlby123's Avatar
shlby123
Thanks fellas. Well the plot is thickening slowly here. I took the truck to autozone and the guy tried running diagnostics on the truck but there's no power to the OBDII port! He tried plugging it in several times and the scanner would not even power up. That's a first for me to hear something like that. Anybody ever have this happen before?
Truck is an '01 too.
Old Jul 27, 2008 | 03:31 PM
biz4two's Avatar
biz4two
Arrow
Could be a blown fuse. Take a look in the ’01 Owner's Manual...and find the location of the fuse for the OBDII port.
Hope that helps...
biz
Old Jul 28, 2008 | 08:26 AM
projectSHO89
Hope that helps...
biz
That fuse also runs the cigar lighter....
Steve
Old Jul 28, 2008 | 09:21 AM
rlh68050's Avatar
rlh68050
Steve
Yes, you have a blown fuse.
Old Jul 28, 2008 | 09:26 AM
shlby123's Avatar
shlby123
Thanks yall!!! Im gonna find that fuse and see If I can get this figured out. That probably wouldnt be the overall reason for the service engine light would it? Just hopeful thinking really, but I'll be happy to put one fire out at a time. I know it was a dumb move probably but I towed my first car with it this weekend too, and it was a dream compared to my old '81
Old Jul 28, 2008 | 09:08 PM
shlby123's Avatar
shlby123
Okay. here we go. So after pulling the fuse, of course it was blown....I replaced it and took it on up to Autozone to get the codes pulled. Just one Code: P0705 I'm hoping this isnt a death sentence but it said the probable causes were a defective transmission range sensor or an open/shorted circuit condition. Could the blown fuse have tripped the light to begin with or where should I go from here?
Old Jul 28, 2008 | 10:18 PM
krewat's Avatar
krewat
I think the range sensor (shifter switch) is a known thing that goes bad sometimes.
Doubtful the blown fuse had anything to do with the code.
More likely that the shifter switch on the side of the tranny is bad.
Old Jul 29, 2008 | 12:05 AM
shlby123's Avatar
shlby123
Is the shifter switch something that I can replace myself? Does anybody know if it is an expensive fix? Im a solid intermediate kind of car work guy, If I have the right tools.
John Hancock
Modular V8 (4.6L, 5.4L)
23
Jun 15, 2019 12:55 PM
monsterballz
Mar 17, 2011 12:28 PM
ETXDIYER
1997 - 2003 F150
May 28, 2010 11:10 AM
oddjobs2do
Sep 3, 2004 10:20 AM
sho02
1997 - 2003 F150
Jun 3, 2003 01:25 AM
