Loosing hair! Please help
Old Oct 25, 2002 | 07:55 PM
gavin_smith_1999's Avatar
gavin_smith_1999
:-X23
I've got a '76 F250 Camper Special 2wd. The turn signals don't work with the running lights on. I've replaced the headlight switch, the flasher, two bad sockets and all of the bulbs. I've also checked the grounds at the sockets and all are good. All other bulbs work. The blinkers work fine with the lights off, but as soon as I turn the running lights/headlights on they quit flashing. Am I missing a relay or something? ANY input greatly appreciated!
Old Oct 26, 2002 | 02:43 AM
sparky's Avatar
sparky
I hate to say it but that is still sounds very much like a ground problem. Have you checked the grounds at the front and the back sockets?
Sparky
Old Oct 26, 2002 | 10:51 AM
Mike W's Avatar
Mike W
When you operate the turn signal switch, does the lamp light but just not flash? If so compare the voltage at the input to the flasher with and without the headlights on.
Old Oct 26, 2002 | 12:30 PM
gavin_smith_1999
Thanks Mike - with the running lights on the flasher filaments don't light at all.
Old Oct 26, 2002 | 12:32 PM
gavin_smith_1999
Thanks Sparky - I've checked all the grounds and am reasonably sure they're operable. Could the two circuits (running lights & blinkers) be shorting together when the running lights are on?
Old Oct 26, 2002 | 02:23 PM
sparky's Avatar
sparky
The running lights use 1 filament in the bulb and the flashers the other one. The common point is the ground, each filament uses the same ground at the bulb socket.
When you turn on the lights with the turn signals off does either of the dash turn indicators glow or lite up?
Sparky
Old Oct 26, 2002 | 08:12 PM
Mike W's Avatar
Mike W
How about the brake lights? Do they work ok with and without the head lamps on?
Old Oct 27, 2002 | 02:16 AM
gavin_smith_1999
Sparky - upon your advice I rechecked all my grounds and the right front ground was bad. Thanks alot!
Old Oct 27, 2002 | 02:42 AM
sparky's Avatar
sparky
No problem glad it is fixed
Sparky
Old Oct 27, 2002 | 09:04 PM
rebocardo's Avatar
rebocardo
BiggB20042001
Dec 6, 2024 08:23 AM
MainetoDC
Jul 3, 2017 09:28 PM
Ammotrp69
Crossovers
Apr 22, 2017 02:14 AM
trevor4234
Nov 6, 2015 07:16 PM
mdbbrown
Dec 28, 2012 01:26 PM
