Crossovers Edge, Taurus X, Freestyle, MKX, Flex etc.
08 edge headlights quit working
Old Mar 18, 2017 | 12:03 AM
Ammotrp69's Avatar
Ammotrp69
My headlights quit working on my 08 edge limited. The bulbs and fuses are fine. I've checked and I have power at the harnesses. High beams, turn signals, parking lights, fog lights all work, just no low beams. I replaced the headlight switch to no avail. What else am I missing?
Old Apr 21, 2017 | 05:47 PM
87 XLT's Avatar
87 XLT
If you see 12 volts at fuse 7 & 8 (10 amps) in the SJB/smart junction box the only thing that makes any sense is that 1 bulb burned out & you did'nt notice until the 2nd bulb burned out. I've been there & done that myself.
Old Apr 21, 2017 | 09:46 PM
Ammotrp69's Avatar
Ammotrp69
actually, no. i jimmy rigged the low beams to the high beams, and the bulbs are just fine. i found that my grounds are gone. i haven't had the time to do it yet, but i'm going to ground them direct to the battery.
Old Apr 22, 2017 | 02:14 AM
87 XLT's Avatar
87 XLT
Someone must have done some creative wiring on these circuits??? The diagram shows the ground wire from left high beam & left low beam are spliced together & are grounded at G 104
Same on the right side and the common ground is G 107.
I hope you don't find any more surprises like this
mechasus
Escape & Escape Hybrid
Oct 25, 2021 04:06 PM
lrh2phish
2009 - 2014 F150
Jan 14, 2019 01:46 PM
$ledgehammer
Aug 26, 2017 11:51 AM
49fordv8f4
Jul 8, 2016 10:10 PM
HUNTER10
Oct 4, 2009 07:40 AM
