NP205 stupid question
Old Jul 25, 2008 | 10:23 PM
plastikosmd's Avatar
plastikosmd
so truck is great..just a stupid question...
I get a buzz/vibration runnin at about 70mph from the transfercase shift lever, if you hold it is gone...faster/slower it is gone...this is prob just some harmonics..but after runnin it a while the lever is also warm to the touch..not hot..prob about my body temp or bit more...is this a sign of impending doom? fluid is normal color and full and clean, no leaks..thanks
Old Jul 25, 2008 | 10:26 PM
ibleedblue1385's Avatar
ibleedblue1385
check the oil?
Old Jul 25, 2008 | 10:35 PM
plastikosmd
as mentioned..clean, full, nl color, more of a light buzz sound...gone if i hold the lever or adjust the boot down or change speeds up or down
Old Jul 25, 2008 | 10:36 PM
ibleedblue1385
it almost sounds the bearings are out if its getting hot.
Old Jul 25, 2008 | 10:39 PM
ibleedblue1385
I know my t-case levers shake alittle. Mostly from the tires and what not. They dont get hot though...
Old Jul 25, 2008 | 10:47 PM
plastikosmd
yea that is why i was concerned...i guess i wouldnt say hot...even after 1hr at 70 mph, just warm...but i wasnt sure..maybe i will go touch the case after runnin it...funny i dont hear it at any other speed.
Old Jul 26, 2008 | 01:55 AM
roxndirt64's Avatar
roxndirt64
Get a bungee cord and hook it to your linkage rod and the other end to the frame or something so there is a little tension on it. That should quiet it down some. If you dont have any metal flakes in the oil and it looks good dont worry about it. If it blows up then you will know where the noise was coming from. lol If its really bothering and you have never been through it put a set of bearings in it.
Old Jul 26, 2008 | 06:32 AM
80broncoman's Avatar
80broncoman
I woudn't worry about the temp of the lever, I be checking the temp of the case its self.
Old Jul 26, 2008 | 07:50 AM
hillbillyk's Avatar
hillbillyk
check the bushing on the shifter mount, sometimes they wear out and makes the lever move around, might heat it up a little.
Old Jul 26, 2008 | 08:57 AM
plastikosmd
thanks guys! ...no great need to drop the case...will check out and see if warm tho.
appreciate it
Old Jul 26, 2008 | 06:24 PM
plowpusher's Avatar
plowpusher
Check the output bearing on the transmission. When you put it in top gear it unloads the output bearing of the transmission causing it to vibrate,which usually goes to the t-case causing the shifter to rattle.
j4henry
May 23, 2011 04:20 PM
learpilot
Jul 13, 2009 05:33 PM
nickyhatch
Offroad & 4x4
27
Nov 17, 2008 12:59 AM
crazyredneckanyhow
Jun 11, 2007 10:19 PM
big truck driver
Sep 15, 2003 05:27 AM
