stupid question
Old May 23, 2011 | 10:12 AM
j4henry's Avatar
j4henry
stupid question
Prob a dumb question but could a badly wore out hub bearing make it feel as if you have a brake sticking?
Old May 23, 2011 | 11:44 AM
Excursionator's Avatar
Excursionator
Just a guess here but that would make sense to me. I mean if the bearing is so bad that it is causing additional friction (what bearings are NOT supposed to do) then I could make the "leap of faith" that it might act like a brake was on. Just a guess.
Old May 23, 2011 | 12:19 PM
EXv10's Avatar
EXv10
If it was that bad your wheel would be ready to fall off (that's not it) and there are no dum questions, not everyone is a master mechanic and they aren't expected to be. Jack that side up and spin the wheel by hand and shake it.
Old May 23, 2011 | 01:02 PM
BassFantasizer's Avatar
BassFantasizer
The only dumb questions is, "does this dress make my backside look big". Actually, it's the guy that tries to answer it that's dumb.
If the bearing was that worn, I would expect the heat buildup to cause it to fail quite quickly.
Have you checked the calipers to make sure that the brakes aren't sticking? Heat buildup in one rotor is pretty easy to detect.
Radial pull. How worn are the tires? When's the last time that the front end was checked out?
Old May 23, 2011 | 01:05 PM
j4henry's Avatar
j4henry
[quote=EXv10;10376346]If it was that bad your wheel would be ready to fall off (that's not it) and there are no dum questions, not everyone is a master mechanic and they aren't expected to be. Jack that side up and spin the wheel by hand and shake it.[/quote
not ready to fall off but verified a couple weeks ago that I need the hub assembly just waiting on enough money to pay for it. there is about 1/2" play in the wheel assembly. but when i am on the road for more that an hour driving, it seems as a brake is dragging
Old May 23, 2011 | 01:13 PM
BassFantasizer
1/2" play in the wheel assembly? How do you measure that?
(This sounds much more like a ball joint....)
Old May 23, 2011 | 01:48 PM
j4henry's Avatar
j4henry
Rough estimate on distance and latex on ground while father in law moved wheel up and down no movement in ball joints but I'm going to do them while apart anyway. That's what I had to do to the other side
Old May 23, 2011 | 04:17 PM
EXv10's Avatar
EXv10
I guess it could cause a drag at the caliper if it is that bad, so that was a pretty smart question.
Old May 23, 2011 | 04:20 PM
EXv10's Avatar
EXv10
You got that right,
sparky
Nov 7, 2002 08:07 PM
proeliator
Oct 5, 2002 01:27 PM
Quantrex
Sep 1, 2002 09:03 PM
dinosaurfan
Jul 7, 2002 03:48 PM
dinosaurfan
Jun 14, 2002 12:46 PM
