Please! My brakes!!!!
Old Jul 25, 2008 | 08:38 PM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
I would say all, at least as far back as 95 as that was the year of my first PSD. We're talking about a 2000 here, not a pre PSD truck.
Old Jul 25, 2008 | 08:48 PM
Greywolf's Avatar
Greywolf
Originally Posted by tag187
most if not all 7.3s will only have the hydro system which uses power steering fluid to build pressure in your hydro boost system which acts almost identical to a full hydraulic system. On a relic of a diesel (not in a bad way) like greys 85 yes they use vacuum but not very reliable or good at braking
Pardon me, I'm an antique at heart.
This is new info for me, makes a lot more sense, and no offence taken.
Can we please return to the age of sail????
Old Jul 25, 2008 | 08:49 PM
Markadeck's Avatar
Markadeck
I asked about the pedal going to the floor during bleeding because I was thinking master cylinder problems.
tag187's Avatar
tag187
I agree 100%
Old Jul 25, 2008 | 08:54 PM
tag187's Avatar
tag187
Ok sorry about the Hijack, like we said before go back check your master cylinder again, then check your electrical after replacing your cab youd be amazed at the electrial bugs that can pop up
Old Jul 25, 2008 | 09:03 PM
tag187's Avatar
tag187
thanks for the rep Greywolf
Old Jul 25, 2008 | 09:34 PM
texasjack's Avatar
texasjack
This year truck has no belt driven vac pump, it has a electrical vac pump that to my understanding operates the ac /heater ducts. I switched the cab because the previous one was crushed on the side, you could still drive it but the doors were caved. But the brakes worked at this point. There is nothing electrical to operate the brakes, only electrical is brake light switch and sensors? I bled the s$&% out of them with my wife ,just like the old 71 blazer! Could it be that new brake booster I bought from O'reilly's? I guess made in china. The master cylinder how to check that?
Old Jul 25, 2008 | 10:17 PM
tag187's Avatar
tag187
On the hydro max booster system you should have an electric pump if not I am unsure so disregard. Here is how to check your master cylinder:
  1. Disconnect the brake lines at the brake master cylinder.
  1. Plug the outlet ports of the brake master cylinder.
  1. Apply the brakes. If brake pedal height cannot be maintained, the brake master cylinder has an internal leak and must be replaced.
As far as your booster yeah it still could be bad I have found that most auto parts stores are not so good for buying diesel parts at.
Old Jul 25, 2008 | 11:04 PM
twags6's Avatar
twags6
The brakes on the 99 and up diesels use the power steering pump to run the hydro booster for the brakes. Pre 99 used a belt driven vacuum pump. There's no electric pump on this system. If the truck shuts down, you have one, maybe two power assisted stops.
The hard pedal sounds like you got a bad booster unit. Did you have to add fluid to the power steering pump when you replaced the booster? If so, did you put power steering fluid or ATF in? Our trucks require ATF in the pump. Regular power steering fluid might mess things up like this.
Old Jul 26, 2008 | 04:00 PM
texasjack's Avatar
texasjack
Thanks guys for the infor, after testing it appears to be the booster. Took it off and bought a new one. Gonna wait and put it on in the morning, its 102f out here right now!
Old Jul 27, 2008 | 06:31 PM
texasjack's Avatar
texasjack
Found problem!
Thanks Tag 187, your copy of the service manual on testing the hydro boost exposed A rebuilt hydro boost I had bought at Oreilly's to be bad when I bought it! So they gave me another and she works! THANKS TO ALL!!!!!
Old Jul 27, 2008 | 07:52 PM
JMac444's Avatar
JMac444
Did you replace any calipers? If you did and set them up the wrong way like the bleeders are facing down instead of up you wouldnt be able to get the air out of the system. You can on the superduties mix the rear calipers by hooking them up backwards putting the bleeders downwards. Just tryin to help with this one, Sounds like you have a bad booster but they ussually dont fail to often.
cdnalpina
Aug 21, 2010 01:06 PM
csangster
Sep 1, 2008 10:27 AM
littlebell
1997 - 2003 F150
Apr 5, 2007 04:07 AM
jrogers693
Oct 2, 2005 06:03 AM
paulg
Jan 1, 2001 01:45 PM
