Please! My brakes!!!!
Old Jul 25, 2008 | 07:12 PM
texasjack's Avatar
texasjack
My 2000 f250 brakes are hard on the pedal, dont go to the floor,and you have to stand on them to make them work. And I've replaced power steering pump, brake booster and bled em 5 times. What the hell could it be?? Please guys some one knows the morsel of infor I need. I replaced the cab on this truck and the brakes have never been the same! Help!
Old Jul 25, 2008 | 07:19 PM
Hiflyer746's Avatar
Hiflyer746
how does the power steering feel? It will take a while to bleed the air out of the system to make the power brakes work. You have to continuously add power steering fluid until all the air is out. How long ago did you do the powersteering pump? Hope this helps.
Timmy
Old Jul 25, 2008 | 07:25 PM
tag187's Avatar
tag187
Are there any noises that go along with the problem. When you replaced the booster did you replace its manifold vacuum hose? Also do you notice any vibration or rattle when brakes are applied?
Old Jul 25, 2008 | 07:29 PM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
While bleeding them, I assume you were using a helper. If so, was the pedal going to the floor when you released the fluid? To tell you the truth, I read on here all of the time and have never seen the problem before.
Old Jul 25, 2008 | 07:40 PM
tag187's Avatar
tag187
Im sorry you said you replaced the power steering system so that means you have a hydro boost system. Check you electric pump and the wiring going to it. Why did you need to replace the cab
Old Jul 25, 2008 | 07:53 PM
Greywolf's Avatar
Greywolf
It sounds to me like VACUUM is missing.
NO DIESEL ENGINE develops vacuum on its own - a VACUUM PUMP is used to make vacuum, and if it has leaks in itself or the lines, the power brake booster does not have the vacuum it needs to apply assist force.
I'd grab (or borrow anyway) a vacuum guage to read the line going into the brake booster and troubleshoot from there on...
Old Jul 25, 2008 | 07:59 PM
tag187's Avatar
tag187
Here ya go man straight from the service manual:
<table border="1" cellpadding="3" cellspacing="0" rules="groups" width="90%"><tbody><tr valign="top"><td>
  • Excessive brake pedal effort
</td><td>
  • Brake booster.
</td> <td>
  • CARRY OUT the brake booster component test in this section.
</td></tr><tr valign="top"><td>
</td> <td>
  • Brake booster check valve.
</td> <td>
  • CARRY OUT the check valve component test in this section.
</td> <td>
  • Brake booster manifold vacuum hose.
</td> <td>
  • REROUTE, REPAIR or INSTALL new components as necessary.
</td></tr></tbody></table>Brake Booster
  1. With the transmission in NEUTRAL and the engine stopped, apply the brakes several times to exhaust the vacuum in the vacuum boost system or the pressure in the Hydro-Boost system.
  1. Hold the brake pedal in the applied position.
  1. Start the engine.
  1. If the power brake system is functioning correctly, the brake pedal can be felt to move downward after the engine starts.
  1. With a vacuum type power brake booster, if engine vacuum is available to the power brake booster and no power assist is felt, replace the power brake booster and retest the system.
If power steering pump pressure is available to the Hydro-Boost power brake booster and no power assist is felt, replace the Hydro-Boost power brake booster and retest the system.
If power steering pump pressure is not available at the Hydro-Boost power brake booster, check the power steering pump pressure and flow. For additional information, refer to Section 211-00.
On a Hydro-Max booster system, if power is available at the electric pump and no power assist is felt, replace the Hydro-Max booster assembly and retest the system.
If power is not available at the electric pump, correct the electrical concern and retest the system.
Accumulator, Hydro-Boost Only
  1. Start and run the engine.
  1. Stop the engine.
  1. Apply the brakes. The accumulator in the Hydro-Boost power brake booster should retain enough pressure for at least two power assisted brake operations. If no power assist is felt, replace the Hydro-Boost power brake booster and retest the system.
Check Valve — Vacuum Booster Only
The function of the power brake booster check valve is to allow manifold vacuum to enter the power brake booster and prevent the escape of vacuum in case manifold vacuum is lost during sustained full throttle operation.
To test the function of the power brake booster check valve :
  • Start and run the engine for at least 10 seconds.
  • Operate the brake pedal to check for power assist.
  • Disconnect the vacuum booster hose from the power brake booster. Do not remove the power brake booster check valve from the power brake booster.
  • There should be enough vacuum retained in the power brake booster for at least one more power-assisted brake operation.
  • Replace the power brake booster check valve if it fails the above test.
Old Jul 25, 2008 | 08:05 PM
Markadeck's Avatar
Markadeck
I don't think our power brakes are run off of that little vacuum motor. I damn sure would not want to count on that for brakes to stop a 7000 pound truck. If there is another vacuum pump this too is something I've not heard about. How can the power steering pump create a vacuum? I think our power brakes are hydraulically boosted.
Old Jul 25, 2008 | 08:09 PM
Greywolf's Avatar
Greywolf
A diesel sure as hell has no vacuum - the throat to the intake is wide open.
THAT RIGHT THERE is why big trucks have air brakes and a reserve tank.
Markadeck's Avatar
Markadeck
Boy, I sure wish I had not posted what I just did.
Old Jul 25, 2008 | 08:12 PM
Greywolf's Avatar
Greywolf
The power steering pump does not create vacuum.
It has nothing to do with brakes.
* (?) Oops.....
(Just trying to be helpful)
I saw the above when it came back.
Old Jul 25, 2008 | 08:17 PM
tag187's Avatar
tag187
the power steering pump provides fluid for your hydro boost system, and yes there is a vacuum system also
Old Jul 25, 2008 | 08:18 PM
Markadeck's Avatar
Markadeck
* (?) Oops.....
Then why do you lose your brakes as soon as you blow your belt off?
Old Jul 25, 2008 | 08:21 PM
Greywolf's Avatar
Greywolf
Because it (the belt) drives the vacuum pump for the system.
Typically - a diesel will have a small plastic globe used as a vacuum accumulator.
It can spring a leak too.
In my old '85 it (the pump) was mounted on the curb side of the Timing case, and it was on it's second one.
Old Jul 25, 2008 | 08:30 PM
tag187's Avatar
tag187
most if not all 7.3s will only have the hydro system which uses power steering fluid to build pressure in your hydro boost system which acts almost identical to a full hydraulic system. On a relic of a diesel (not in a bad way) like greys 85 yes they use vacuum but not very reliable or good at braking
