All... i have an 01 f250 7.3 diesel. At times, when i put it in reverse, it acts like i put my foot on the brake at idle, and let the clutch put, and it stalls. The only problem is it's an auto trans!! Also, when it doesn't stall, it still acts like a stick when your letting out the clutch and slowly giving it gas. It slowly slips into gear just like a stick shift. has anyone every experienced this?? Any ideas?? Thanks, jeff
Have not experienced that particular problem, but I do know that reverse is the only manually controlled gear in our POS transmissions. All of the forward gears are controlled by the PCM.
Isn't the torque converter suppose to unlock when in reverse? I thought it was and that is why the tranny heats up so quickly when in reverse. I'm guessing here, but perhaps the torque converter is staying locked up when it stalls (like when someone who has put a manual TC switch in and forgets to unlock the TC as they slow down for a stop). When was the last time you flushed the tranny? Mark Kovalsky will know...calling Mark!
I'm pretty shure the tourque converter unlocked dosnt grab enough at low rpms to stall the motor., So no matter whats going on behind it, it wouldnt stall UNLESS the TC was locked.
I changed the tranny fluid about 6000 miles ago. I just started experiencing this about 1000 miles ago. It acts just like the manual tranny i wish i had!!!
Reverse is not the only gear that is manually controlled. The torque converter is supposed to be unlocked in reverse, but it's also supposed to be unlocked in first gear.
The problem is that the torque converter clutch is on in reverse when it shouldn't be. There are several reasons it might do that.
Low trans fluid.
Loose internal filter.
Internal leakage.
Bad torque converter clutch solenoid (on the valve body.)
Stuck torque converter clutch valve (in the valve body.)
Bad PCM.
Bad torque converter.
Low trans fluid.
Internal leakage.
Bad PCM.
