It even fits in there without cutting the firewayy, just the rad has to go in the back.
You cant say an f250 new body style with a 466 wouldnt be awesome. Box space would be lost due to rads and coolers, but man, what beats being able to lay down up to 2500 hp next to a 400 hp cummins ram?
You wouldnt lose that much space I dont think, but 2500 hp does sound like some fun..
Actually, a stock 466 radiator dosnt look any bigger than the 7.3's rad, however, I'm sure that once the engine produces over 1000 hp, instead of 300, things may heat up a little.
I've been contemplating where all those radiators would need to go....
Best Idea i had so far, is to butcher a fiberglass box cover into a giant radiator fan mounting system, and install a towing tailgate with the fins, so that air gets sucked in the top, and out the back.
I tow a bumper pull camper, so no 5th wheel hitch.
Electric fans could be installed on the finned tailgate, and with proper protective grills around the fans and rad's, stuff could still be stored in the box.
As long as it aint gonna overheat.... (not a good place for the wifes candles...)
Where ever you mount them, it sounds like alot of hose is goin to be needed lol.
You always have some pretty crazy, roached out ideas.
