axles
Old Jul 25, 2008 | 07:34 AM
fordnut2008's Avatar
fordnut2008
axles
hello everyone... i have 1980 f100 4x4 that i got the other day... seems to be a good truck it has a smaller lug pattern on the rear... i have seen them like that before... i just wanted to know if you can swap out the axles ... i know there are different splines in some of them... if any one has run into the same problem let me know what you had to do... thanks.
Old Jul 25, 2008 | 09:06 AM
quaddriver's Avatar
quaddriver
Its not a 5 on 5.5? I would have guessed that the 9 inch rear it likely has would be that way - my 81 F100 has one and the bolt pattern is the same as my 8.8s. A smaller pattern sorta indicates someone stuck in axles from an 8 inch....
Old Jul 25, 2008 | 02:46 PM
fordnut2008
yeah it's a 5 lug just a smaller pattern i don't why they done that you got to have 2 different rims i have a set of those aluminum rims that was on most 76 4x4's and i can't use them because of this lug pattern on the rear i will try and see if i can change the axles.
Old Jul 25, 2008 | 02:49 PM
ibleedblue1385's Avatar
ibleedblue1385
Prolly a 28 spline 9"?
Old Jul 25, 2008 | 06:43 PM
Franklin2's Avatar
Franklin2
Some of the f100's had the smaller car pattern wheels. But I have never heard of a f100 that was a 4x4. I bet you have the original axle in the rear, and a f150 axle swapped into the front. Measure the width of your rear springs. If they are not 3 inches wide, then you have a 2 wheel drive truck that has been converted to a 4x4.
justintyhme
Jul 29, 2014 06:12 AM
nct53
Nov 7, 2011 02:12 PM
97XLT4X4
All Things Towing
Apr 18, 2011 11:33 AM
Hottemp
Aug 7, 2003 08:27 PM
