axle rating
Old Mar 29, 2011 | 02:46 PM
97XLT4X4's Avatar
97XLT4X4
axle rating
is there a stamp or something on trailer or the axle so you know the weight rating on the axle. i was told my trailer has a 5k axle when i bought it...thanks.
Old Mar 29, 2011 | 06:25 PM
senix's Avatar
senix
Data plate should tell you if you have one.
Old Mar 29, 2011 | 06:52 PM
97XLT4X4's Avatar
97XLT4X4
you again.....lol
wheres that?
Old Mar 29, 2011 | 06:57 PM
TexasRebel's Avatar
TexasRebel
if you cant find a plate, you can check the number of lugs against the name...
if you can't find a name, you can remove one of the bearings and take it to a place the services trailers... that should be enough to identify it.
It's probably something like this
http://dexteraxle.com/i/u/1080235/f/..._Lbs_12-10.pdf
Old Mar 29, 2011 | 08:23 PM
97XLT4X4's Avatar
97XLT4X4
where a data plate?
texas: you confused me 100%
Old Mar 29, 2011 | 08:48 PM
TexasRebel's Avatar
TexasRebel
generally speaing, a 5 lug trailer axle will have the smallest weight ratings from a particular manufacturer. Next are the 6 lugs (1 axle), then the 6 lug tandem axles, then the 8's (generally always tandem), then there are tri-6's and tri-8's along side of dual, tandem dual, and I've even seen some tri-duals...
simply, the number of lug nuts on the axle is a good indication of the weight rating.
Old Apr 15, 2011 | 04:39 PM
97XLT4X4's Avatar
97XLT4X4
bump....
my axle is a 5 lug, tires are rated for about 1800 pounds each...i feeling more a 3500# axle
Old Apr 16, 2011 | 11:52 AM
Otahyoni's Avatar
Otahyoni
I would agree. I would think a 5k axle would normally be 6 lug.
Is this a single axle small trailer? like a 6x10 or something?
Old Apr 16, 2011 | 12:19 PM
97XLT4X4's Avatar
97XLT4X4
yes sir, its 6.5x12
Old Apr 16, 2011 | 03:27 PM
minitrk's Avatar
minitrk
3500# axles will be in a 6.5x12
Old Apr 18, 2011 | 11:33 AM
Diesel Man 03's Avatar
Diesel Man 03
My 5'er has tags on them that say 5200 lbs, they are 6 lug rims.
1975FordF250
All Things Towing
Feb 5, 2018 09:33 PM
my996duc1
6.7L Power Stroke Diesel
50
Jan 1, 2012 12:56 PM
loganworks
Jan 16, 2011 10:47 AM
44dwarf
Feb 17, 2010 11:09 PM
-Mike-
Dec 3, 2006 07:38 PM
