Offroad & 4x4
axle wrap
Old Jul 23, 2008 | 09:38 PM
freejay's Avatar
freejay
axle wrap
My truck has pretty soft springs on the front and with 44s it likes to destroy the bottom u-joint on the front driveshaft. I'm thinking I have quite a bit of axle wrap goin on. What do you guys think of this as a solution?
It would replace the plate on top of the spring pack. I would mess around with the length and angle so it would be effective in forward and reverse. Maybe put some rubber or poly bumpers at the back end so it wasn't noisy...
Let's have it
Old Jul 23, 2008 | 09:48 PM
ibleedblue1385's Avatar
ibleedblue1385
What is the driveshaft/ujoint binding up?
Old Jul 23, 2008 | 09:53 PM
freejay's Avatar
freejay
Well if I'm thinking about this properly, when going forward the pinion would twist down, which I think is causing the joint to bind
Old Jul 23, 2008 | 09:55 PM
ibleedblue1385
Hows your pinion angle?
Old Jul 23, 2008 | 10:14 PM
freejay's Avatar
freejay
It's fine when at rest, I couldn't point it up too much though or my steering would suffer on the road
Old Jul 23, 2008 | 10:21 PM
DesertStorm's Avatar
DesertStorm
Let's have it
Track/ladder bar
Look at my topic a couple days back. I think it is a good one. Shows a good design, cheap, effective and can be applied to a front axle as well.
Old Jul 25, 2008 | 10:28 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow
Why not just cut and turn the "c"s on the axle to better the pinion angle?
freejay
17
Feb 10, 2014 02:04 PM
freejay
Aug 23, 2009 06:22 PM
freejay
Feb 23, 2004 08:01 AM
freejay
15
Aug 29, 2003 09:57 PM
freejay
May 20, 2003 10:10 AM
