HELP!!! Oil Drip
Old Jul 22, 2008 | 05:40 PM
Timon5435's Avatar
Timon5435
HELP!!! Oil Drip
just discovered oil drip. Is this normal for 6.0L Looks like on the rear side of oil pan. Not a lot of dripping just maybe a few of drips over night.
Old Jul 22, 2008 | 05:41 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Thread moved. There are various reasons for oil leaking off the rear of the 6.0L, these guys will help you pin it down
Old Jul 22, 2008 | 09:37 PM
Timon5435's Avatar
Timon5435
how do I get to that thread...found it!
Old Jul 22, 2008 | 09:54 PM
bismic's Avatar
bismic
Oil leaks can be troublesome w/ the 6.0L. The best way to find the specific source is to clean it up and take it in to the dealer so that dye can be added.
<TABLE style="WIDTH: 557pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=743 border=0 x:str><COLGROUP><COL style="WIDTH: 557pt; mso-width-source: userset; mso-width-alt: 27172" width=743><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 557pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=743 height=17>Most Common Places for Oil to Leak (use a dye to find actual leak point)</TD></TR><TR style="HEIGHT: 51pt" height=68><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 51pt; BACKGROUND-COLOR: transparent" height=68>http://www.forddoctorsdts.com/excerpts/index.php</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>CAC Tubes = 21%</TD></TR><TR style="HEIGHT: 25.5pt" height=34><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 25.5pt; BACKGROUND-COLOR: transparent" height=34>ICP Sensor = 16%</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Glow Plug Harness = 14%</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Cam/Crank Position Sensor =14%</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Front Crankshaft Seal = 8%</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Upper to lower block seal (skirt) = 5% (bedplate)</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>http://dan.prxy.org/Truck/6L_bible_html/html/Page_022.html</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>HPOP cover = 4%</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Oil Cooler (this leaks into engine coolant) = 4%</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Front or Rear Engine Cover = 3%</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Rear Crank Seal = 3%</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Turbo Charger & VGT actuator = 2%</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Covers (oil pan, valve covers, breather) = 2%</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Cracked or Porous Block or Head = 1%</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>IPR valve/Engine Lube oil pump = <1%</TD></TR></TBODY></TABLE>
Old Jul 22, 2008 | 10:05 PM
bismic's Avatar
bismic
Here are some links to previous threads:
<TABLE style="WIDTH: 557pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=743 border=0 x:str><COLGROUP><COL style="WIDTH: 557pt; mso-width-source: userset; mso-width-alt: 27172" width=743><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 557pt; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=743 height=17></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl26 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>https://www.ford-trucks.com/forums/622121-oil-leak.html</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl26 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext; BORDER-LEFT: windowtext 0.5pt solid; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>http://www.forddoctorsdts.com/photographs/index3.php</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 557pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=743 height=17>http://intellidog.com/dieselmann/60bulletin.htm
<TABLE style="WIDTH: 146pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=195 border=0 x:str><COLGROUP><COL style="WIDTH: 146pt; mso-width-source: userset; mso-width-alt: 7131" width=195><TBODY><TR style="HEIGHT: 51pt" height=68><TD class=xl24 style="BORDER-RIGHT: windowtext 0.5pt solid; BORDER-TOP: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 146pt; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 51pt; BACKGROUND-COLOR: transparent" width=195 height=68>https://www.ford-trucks.com/forums/710857-2006-6-0-l-diesel-engine-oil-leak.html</TD></TR></TBODY></TABLE>
Old Jul 23, 2008 | 01:38 PM
Ronin-M5's Avatar
Ronin-M5
I hate drips on my driveway and my 06 F-250 now has developed a small leak after it is driven. Once the truck is parked the drip goes away, but after driving it and parking, there will be a few drips.
I have taken it to the dealer and they stated it is the CAC tubes and since I have the Banks IC and Intake, that they are not responsible for it. I have read that there is a crankcase vent that goes into the CAC tube.
Can I just remove the tubes and clean them out? Why does oil get in there? Is it somehow related to the Banks IC?
Old Jul 23, 2008 | 06:01 PM
bismic's Avatar
bismic
The CCV (Crankcase vent) puts several tablespoons of oil (typically) into the turbo inlet tube every 5000 miles or so. The only way to prevent this is to re-route the ccv. Some people route it to the back of the vehicle, or to the side and let it drip. Some people put a filter on the end to avoid sucking dirt into the vent tube. The method I chose was to install a frame rail mounted coalescing filter and run the ccv to it and then return the vent to the turbo inlet tube. Works well for me.
Also, yes you can remove the tubes and clean them. Sometimes the CAC tube can blow off from being oil soaked. It can then be hard to get it to stay on. The tube that resists this the best is the one with the orange liner IIRC.
