1978 - 1996 Big Bronco
Leaking Tranny
Old Jul 22, 2008 | 04:56 PM
buckeyebronco's Avatar
buckeyebronco
Thumbs down Leaking Tranny
So my transmission AOD, started leaking a while ago. I tightened up the pan bolts and it stopped for a few days but then started again. As of right now I can't exactly determine where the leak is from. What are the most likely areas that a transmission leaks from. Currently it looks like it could be coming from the pan, the fluid fill, or the belhousing. I will have to use some degresser to clean the area up first to find out where it is leaking from right?
Old Jul 25, 2008 | 08:35 PM
helirich's Avatar
helirich
Yea that's the plan. I had a leak in my front seal. I put trans-x in and it stopped, much to my amazement. I talked to a transmission man and he said it swells the seal to stop the leaks. He also said that when it goes to leaking again, it will leak really bad. But it may not do that for awhile.
Old Jul 28, 2008 | 11:03 AM
buckeyebronco
Well I changed the fluid, filter and pan gasket this weekend. One my way to Miami I did not have any leaks like last week so hopefully that was it. I also put in some Valvoline Max Life tranny fluid that is supposed to do the same thing. 1:6 ratio is what it said with mercron V.
patrick77598
23
Sep 29, 2013 07:21 PM
apeman426
Oct 11, 2012 12:46 PM
RustyBeach77
1997 - 2003 F150
Jul 19, 2012 01:16 PM
MK75Gunner
Jun 17, 2012 12:58 AM
beached350
Feb 24, 2010 05:22 PM
