I changed my tranny fluid about 1,500 miles ago and now all of a sudden the pan started leaking at the back. I'm sure its leaking from between the tranny and the pan cause I can clean it real good and watch it with a bora-scope.
I figured the OEM gasket was bad to I went to the dealer and got another but it did not fix it. While I had the pan down I took a straight edge and the pan looked good except one bolt next to the leaking area is a bit low. I had access to another pan and interestingly it was the same. Right now I have the bolts torqued to about 14 lb/ft and it's still leaking.
Update:
Here is a picture of where it is leaking from
It seems to be seeping from between the pan and tranny where I'm pointing, I dont think its the rear seal because I cleaned it very good and there is no fluid higher up.
Patrick
Edit: When you put the pan back on does the gasket and both surfaces need to be dry? I always coat all three in a bit of fluid?
Edit 2: I read on another forum that over tight bolts can dimple the pan around the bolt holes and now that I think of it when I pulled the pan for the first time to do a front seal change I remember thinking OMG these bolts are tight, I wonder if the bolts were over tightned and dimpled the pan? How can I fix that?
The pan is a decent piece, but why do you want to spend that much money on a pan? What does it do better than the stock pan? Hint: I don't ask this question without knowing the answer before asking it.
Well an update, I picked up some Permatex gasket sealent on the way home from work and put it on and the pan is still leaking in the smae place which makes me wonder if it is the joint between the tranny and the tail stock that is leaking.
Mark, I was just looking for a pan with a better mounting flange but it doesent look like it will help. on a 4X4 tranny is there fluid in the tail stock? If its leaking from the joint right at my finger tip what does this mean?
The leak appears to be coming from between the tailhousing and the transmission case. The transmission could be raised, remove the housing, replace the gasket, and reinstalled. I would spray the area with brake cleaner, blow it, off with compressed air, and watch it. The pan slightly overlaps the joint and can give the impression the pan gasket is leaking.
So on a 4X4 truck the output shaft of the tranny is just sealed by a bushing? then the fluid that gets past that goes into the extension housing and from there drains back into the tranny pan through an opening in the bottom of the housing? (where the rod goes through in the first picture) The input to the transfer case is where the seal is that keeps the transfer case fluid in and the tranny fluid out?
im just trying to figure out where all it could be leaking from and what all I should replace while i have it all apart again.
There is also a plastic orifice that presses into the back of the case that provides lube for the the Park/OSS gear and linkage. The transfer case input shaft seal is double lipped.
I wonder if I should replace the transfer case seal while I have it out? the truck has 175K miles on it.
Are any of the gaskets better than others? I see Napa has one for $1.25? how about the transfer case seal any better ones of those like there are for the front seal?
The gaskets are pretty much the same. Clean dry surfaces with a light film of RTV wouldn't hurt. I generally install it ”dry” on mine. I have 214k on my transfer case seals and don't intend to change them any time soon. No leaks. No problem. Leaving well enough alone.
Update: So after work I decided to pull the drain (upper) plug and fluid came gushing out, between what went on the ground and what went in the jug about 2.5 quarts came out. So from what I have read this could be caused by a bad seal?
Yes. It's really the only way the transfer case can overfill with ATF by itself.
