65 or 66
Old Jul 22, 2008 | 04:44 PM
catskinner789's Avatar
catskinner789
65 or 66
Ok so i have a 1965 f100 with the 240 I6 when looking for a good repair manual i have found the for the 1966 for much cheaper. So was wondering if there is much difference between the two years?
Old Jul 22, 2008 | 04:48 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Welcome to FTE
Very little difference...same engine/trans/rear end/steering/suspension/brakes.
The major differences: 1966's have smog pumps, slightly different accelerator linkage, the '66 F100 4WD's are slightly different from 1965's.
However, the '66 Ford truck shop manual may only be a thin supplement to the 1965 manual (why it's prolly cheaper). Better make sure before you buy it.
The supplement only covers the few differences.
Used and reprinted Ford shop manuals: faxonautolit.com
Old Jul 22, 2008 | 05:50 PM
garbz2's Avatar
garbz2
Only in cali on those smog pumps Bill......The rest of the real world did not have to deal with them till much later.....
So dont go and look for your missing smog unit in your New Jersey delivered 66.
My dads spankin new 66 F100, 70F100 74F100 79 F150 had no cats or pump.....In PA of course...
Garbz
Old Jul 22, 2008 | 06:38 PM
NumberDummy
Originally Posted by garbz2
Only in cali on those smog pumps Bill......The rest of the real world did not have to deal with them till much later.....Garbz
Whatever you say, kiddo.
Since I was born in LA, raised in LA, and spent 35 years as a partsman in LA, I know that the pumps were on CA vehicles, what the rest of the world used, I dunno.
Parts catalog doesn't say CA only on the smog pumps...and stuff that was CA emissions only is specified in other places in the catalog.
And....the shop manual does make mention of them, CA or not.
Old Jul 24, 2008 | 12:44 AM
Col Flashman's Avatar
Col Flashman
Welcome to FTE
N.D.
Speaking of Accelerator/Throttle Linkage on the '65-'66, that's a Mechanical Linkage & not that lame Cable system correct?
I'm unable to find my manuals to verify & I need to locate a Mechanical Linkage set-up, as I'm have sticking problems w/ the cable causing the engine to race while attempting to stop & the peddle tends to fall foreword as well, which is extremely irritating on both counts, could you help, please?
Old Jul 24, 2008 | 01:08 AM
NumberDummy
Originally Posted by Col Flashman
N.D.Speaking of Accelerator/Throttle Linkage on the '65-'66, that's a Mechanical Linkage & not that lame Cable system correct? No.
Lame cable setup used in 1965/66, and there's more than one cable, so if you go with another cable...you'll have to measure the old one.
Parts catalog illustration shows that '67/72 F100/350's didn't use a cable...it's all mechanical...all you have to do is find one of those.
You're welcome to swing by and take a look at the illustrations.
Old Jul 24, 2008 | 01:16 AM
Col Flashman
N.D.
Coolness, I've to have the wife into work @ 0700hrs tomorrow.
When would be a good time to knock you up in the morning?
Old Jul 24, 2008 | 02:02 AM
NumberDummy
N.D.
Swing by on the way home....
Remember where we live? About two miles up the hill from the corner of walk and don't walk.
WARNING! There are 5 of them here now = FIVE!
Prepare yourself to be inundated by Basset Hounds!
Old Dec 27, 2008 | 12:22 AM
1966CCCAMPERSPECIAL's Avatar
1966CCCAMPERSPECIAL
I have an original california 66 f250 352 with no smog pump from the factory
Old Dec 27, 2008 | 05:48 AM
NumberDummy
Smog pumps were installed after 1/1/1966 on all the cars, Econolines, Bronco's and F100/250's in CA.
No smog pump: Your truck was either assembled in 1965, or the system has been removed.
Coastal68
52
Nov 20, 2014 12:08 PM
dieselkid
16
Dec 6, 2009 02:15 AM
CharlieLed
Mar 9, 2009 04:54 PM
bronco351
1978 - 1996 Big Bronco
Sep 30, 2002 12:33 PM
