I have a '68 Camper Special with a sluggish 360. It runs okay but it will eventually need a rebuild. This is a daily driver for me; to work and back, a few brief trips down the interstate a month, etc.
So, naturally, I'm thinking about more power. My question is, how much is too much? I want more power but no so much that the thing becomes difficult to control or uncomfortable to drive.
How much money do you have? A nice 390 with an rv cam, headers and a 4 bbl with an aluminum manifold should get a nice daily driver with decent mileage.
I was talking to an older guy who built hot rods in his youth. He was saying something like "you can build an engine with 400 or 450 horsepower, but the thing becomes difficult to drive in traffic and run on pump gas" and so on. He was talking about his experience in the 60s and 70s.
So what do you-all think? Is 400 horses too much for a 5000 pound daily driver?
350-400 hp range but don't forget torque.Torque more important than HP We're talkin' about a Bump here not a light Mustang. Even though I said that Fastion your FE like the factory 428CJ Mustang's numbers. It's numbers were torque biased. It was rated at 440 LBs of torque and 335 HP (wink).
Good points. I'm really just looking for a little fun with this, I certainly won't be racing it.
Budget isn't a problem.
Some things that would make a rig more work and angst to drive, regardless of HP, includes (in my opinion):
Too radical a cam..
Borderline or actually overheats
Too noisy/loud/obnoxious
Too low (numerically high) rear gear for highway use
Really crappy MPG... anything less than 10 or so.
Unreliable
Idles at 1500 RPM
10.8 or higher compression and requires race gas or a race gas mix.
Barely passes emissions (if subject to testing or visual inspection).
That FE block will provide all the power that your Camper Special with it's stiffer springs needs as well as drink all gas you can pour in it.
You can rebuild that engine, bring the compression up, add headers maybe a small 4 barrel and have adequate power. Use the 360 block get a 390 crank & rod set and make a 390 out of it.
You can go over if you like but you will pay for it at the gas pumps.
John
That sounds just about right. It doesn't sound like a ton of money either.
"...drink all gas you can pour in it." They'll do that!
The rear springs are the weak point, wheel hop and ujoint destruction happen on even a mildly warmed over truck. I blew the driveshaft out on my F250 with a torque-build 360, loaded heavy. I take it very easy in the two low gears now with the diesel. It's only 180hp, but 375ft/lbs in factory trim, and it's been turned up from that so it wheel hops really bad when traction is limited. In wet weather it's a handful, in the snow it's a nightmare.
