tranny
Old Dec 4, 2009 | 05:41 PM
dieselkid's Avatar
dieselkid
tranny
so how much oil goes in these trannys?? cuz my bro had a line pull off and all the oil came out.
so how much oil do i have to put back in this beast???
Old Dec 4, 2009 | 05:56 PM
starmilt's Avatar
starmilt
Hopefully it didn't drain it all out I would start with a couple quarts and check it until full.
Then don't let bro drive it anymore if he's pulling tranny lines off. lol
Old Dec 4, 2009 | 08:23 PM
wreckinball's Avatar
wreckinball
am i missing the type of trans?
Old Dec 4, 2009 | 08:49 PM
johnboggs21's Avatar
johnboggs21
stars advice is generic, so that works. But it would be helpful to know if we are dealing with a C6 or E4OD.
Old Dec 4, 2009 | 08:51 PM
starmilt's Avatar
starmilt
84 would be a c6.
Old Dec 4, 2009 | 08:56 PM
johnboggs21
oops didnt notice the little 1984 Ford F-250 under his username lol
Old Dec 4, 2009 | 09:24 PM
starmilt's Avatar
starmilt
lol that may not be what he is working on though. The reason I said to start with 2 quarts is I hope he didn't drain all the oil and it is easier to put it in than take it out.
Old Dec 4, 2009 | 09:35 PM
damac's Avatar
damac
We are going to service ours on our newfound junker this weekend. If the literature I have found online is correct, it says 12 quarts.
Only thing I don't know though being new to these trucks and not having a manual yet, is our 85 has a aux tranny cooler on the front of the radiator/ac unit.
So how much if any does one of those add to the fluid needed?
Old Dec 4, 2009 | 09:42 PM
starmilt's Avatar
starmilt
Not much for the cooler ,but the 12 quarts is if everything is dry. If you dont drain the converter it will be more like 4 quarts.
Old Dec 4, 2009 | 10:46 PM
wreckinball
well yeah i asked about the trans because i have a 1989 F350 Chassis, 1994 F150 extracab body, C6 trans etc etc etc. There can be no assumptions anymore! Not after my truck. Just ask dave s and the other fellas when they were helping me with my GP system. They were telling me yellow wires and black wires when i was seeing purples and greens and black etc. hahaha
Old Dec 5, 2009 | 12:33 AM
starmilt's Avatar
starmilt
Maybe your handle ought to be oddball instead of wreckinball lol.
Old Dec 5, 2009 | 02:53 PM
dieselkid's Avatar
dieselkid
i think it pritty much drain my hole tranny....
i belive i have a front tranny cooler that runes to my radiotor. becuz that the line that came off so i was told, after towning his *** home but the only realy thing im hoping is he didnt mess up my torque converter cuz from my knowlage u need to run oil thru them to keep em working. correct?
Old Dec 5, 2009 | 05:00 PM
starmilt's Avatar
starmilt
The tranny should have started slipping at just a couple quarts low and storred pulling at about 4 quarts so it should not be completely empty unless it was left running trying to go, in which case damage would occur.
Old Dec 5, 2009 | 05:10 PM
kenpobuck's Avatar
kenpobuck
My chilton says 23.5 pints for the 79-86 c6 which is about 3 gallons. I am currently putting an other tranny in mine.
Old Dec 5, 2009 | 05:23 PM
starmilt's Avatar
starmilt
How far did you tow it and did you put the tcase in nuetral or remove the driveshaft.
