brakes falling pedal
Old Jul 20, 2008 | 05:36 PM
rblaine9000's Avatar
rblaine9000
hello all Have a good question for you?
1992 f-150 straight 6 manual tranny on second engine and fifth master cylender!!!!!! from oreilly auto.....
A....does anyone have any special things they do when replacing master cyl..
B...When you press brake pedal(engine running)it slowly falls
C...Would the booster be at fault or is this possibly the fifth bad master cylendar from orielly's that i have recieved?????
I am bleeding from furthest to closest ect... any suggestions!!!!!!!!!!!!!!!!!!!!!?????????????????? ?????????????????
Old Jul 20, 2008 | 05:53 PM
danr1's Avatar
danr1
Do you "bench bleed" the master cylinder before connecting and then bleeding the lines?
The term "Bench bleeding" is kinda misleading if you're not aware, it can be done on or off the truck. Solid plug the line outlets and cycle the piston until you see no more bubbles or use a kit. I prefer the kit, very cheap to buy and works without fail and can see the results as you use it better.
If you've done that, bench bleed it, then it sounds like you need a new MS again. Maybe get one from another source?
Old Jul 20, 2008 | 07:05 PM
Emiliojr's Avatar
Emiliojr
Danr1 is right, bleed the master first then the lines.
Old Jul 20, 2008 | 09:58 PM
EPNCSU2006's Avatar
EPNCSU2006
If the ABS valve is leaking internally, it can cause the same symptom of a falling pedal.
Old Jul 20, 2008 | 11:01 PM
rblaine9000
where is this abs valve??????
Old Jul 21, 2008 | 04:33 AM
EPNCSU2006's Avatar
EPNCSU2006
driver side frame rail, almost directly under the firewall.
Old Jul 21, 2008 | 05:55 AM
Lazy K's Avatar
Lazy K
Spot on. I had the same problem as you describe, a good brake pedal untill stopped at the lights or wherever and the pedal would slowly sink to the floor. It turned out to be a faulty solenoid valve in the RABS valve body allowing fluid to flow into the chamber with the spring loaded piston. If you think that may be your problem there is an easy test. On the front of the RABS valve body there is a large hex plug. Unscrew that plug (be careful it is under spring pressure all the way) and remove the spring. Replace the plug. Pump the brakes and if necessary bleed the RABS valve. If pedal no longer sinks then the valve body is faulty. I drove mine for two years before I replaced the RABS valve body.
Old Jul 21, 2008 | 05:34 PM
rblaine9000
is this the proportioning valve????
Old Jul 21, 2008 | 05:38 PM
rblaine9000
I removed spring and no more sinking pedal ,but!!!! my pedal falls half way down before pressure is felt...I don't know but I think we are going in the right direction.I have to wait till tommarow to get help to bleed system then will reply but I wan t to klnow exact name of valve
Old Aug 22, 2011 | 09:22 PM
jeffwolfe125's Avatar
jeffwolfe125
Need help with this same issue in a 1992 F-350 dually diesel. We have replaced the master cylnider, the booster, and the RAB valve, calipers and wheel cylinders do not leak and the pedal still drifts. We have great brakes, but once you are stopped and holding your foot on the brakes they begin to drift to the floor. Any ideas what it could be?
Old Aug 22, 2011 | 11:13 PM
White 97 xlt's Avatar
White 97 xlt
You have a leak somewhere or you got a bad master cyl..
BTW....You did know this thread is over two years old, didn't you?
Fastback460
26
Jun 18, 2015 08:29 PM
dougjohnson72
Jan 17, 2014 09:58 PM
CollinsCD
26
Dec 27, 2013 02:10 PM
96f150
1997 - 2003 F150
15
Sep 21, 2013 07:02 PM
tonysquirrel
Jul 25, 2004 04:59 PM
