DUMB Questions here........
Old Jul 19, 2008 | 10:34 PM
F350-6's Avatar
F350-6
Originally Posted by jeremy53402
What about the hard starting? Is that how long it takes for the injectors to operate?
No. It should start within 2 or 3 seconds. Can you describe the injector noise you hear just before the engine starts? When it finally does start, does it idle normally?
Old Jul 19, 2008 | 10:36 PM
jeremy53402's Avatar
jeremy53402
Originally Posted by megawatt00
Does the oil pressure climb steady? or "peg" ? If it pegs then the sensor is bad. I had a bad temp sensor and that is what happened. It would get to a certain temp and then climb very very quickly to the top.
That sound exactly like what is happening.
Old Jul 19, 2008 | 10:39 PM
jeremy53402
When it turns over, is it doing it quickly? Have you tried to charge the batteries then start it?
I have a battery booster on it.
megawatt00's Avatar
megawatt00
The oils pressure sending unit is most likely bad. It gets to a certain pressure then "shorts" out giving you a higher reading.
Old Jul 19, 2008 | 10:41 PM
zx250's Avatar
zx250
Of the next Riffraff East
Jim, would that cause the no starts?
megawatt00's Avatar
megawatt00
Thumbs up
Is this on when you are trying to start it? How is the fuel in the bowl? Is it draining back when the truck is off? Oil level and right type of oil?
Old Jul 19, 2008 | 10:42 PM
jeremy53402
Remember I am inside a van with the dog house off. I can hear everything. I hear a real rapid clicking or electrical snapping going on every time just before it starts.
Old Jul 19, 2008 | 10:45 PM
megawatt00's Avatar
megawatt00
Just for the heck of it check your grounds. If a ground is loose or dirty you may here some of the relays chattering. As the current flowsthrough the "bad" ground it heats up and makes contact.
jeremy53402
Is that the sensor on the HPOP cover left side?
Old Jul 19, 2008 | 10:52 PM
zx250's Avatar
zx250
Clicking or chattering relays is a good sign of weak electrical connections. Either bad batteries, bad connections or maybe a bad grounds.
Old Jul 19, 2008 | 11:00 PM
F350-6's Avatar
F350-6
I believe the oil pressure sensor is the one on top of the HPOP reservoir and the oil temp sensor is the one on the side.
I understand you're sitting a lot closer to the engine in the van, but I've had my head under the hood during start ups and don't recall hearing these clicks.
I don't think that sensor is your slow starting issue. I agree the clicking sounds more like an electrical issue and that could easily be the slow start problem.
megawatt00's Avatar
megawatt00
I think so but I'm not to sure. Let me look and see if I can find it for you.
Old Jul 19, 2008 | 11:14 PM
  #28
jeremy53402
Man! This engine just can't get right. I still can't figure out what caused the left bank on the original engine to over heat so bad it melted the valve cover gasket and stick 3 pistons. The right side is perfect. Now a new engine and I'm scared that the old problems are going to make this engine self destruct.
Old Jul 19, 2008 | 11:19 PM
  #29
jeremy53402
I have had scaners on this limo coach and the only this that comes up is the oil back pressure problem. Which I don't think is very important. How would I figure out the possible electrical problem?
Old Jul 19, 2008 | 11:21 PM
  #30
megawatt00's Avatar
megawatt00
If it is'nt a grounding problem for the start then this may be it:
