PMS'n today
Old Jul 19, 2008 | 10:33 AM
79_250RangerLariat's Avatar
79_250RangerLariat
PMS'n today
Shimmed the FPR and put on the HPX today, made the engine feel stronger. Fuel pressure from 60 psi to 75, about had a Oh #$& moment though!
While doing the FPR I put a dab of grease on the spring to hold the bb, no problem. Used a mirror to make sure everything went in to place, no problem... Put on the cap, made sure the tit was in the spring...started to tighten and heard spring noise as I made my final tighten... Didn't think too much of it. Fired the truck up and 120 psi!
Pulled it back apart and found the spring tweaked to the one side..... Knocked out the piston, removed the bb, straightened the spring and had 50 psi...aww crap... Thankfully I don't usually throw stuff away (have a filter housing off one of my old IH busses in the shed. Pulled the spring out of it and used it as a guide to straighten the ford one again). This time I knocked out the piston, put the bb in the piston, spring in the piston an reassembled as one unit. Leaving it sticking out of the FPR just enuf to gaurentee the tit on the cap was in the spring.
Worked like a charm, fired it up and have around 75 psi. Now gotta finish off the gauges and wait for the TW to show up, should be here by wed
Old Jul 19, 2008 | 10:41 AM
jimwilsonmasonry's Avatar
jimwilsonmasonry
congrats on the job well done
Old Jul 19, 2008 | 05:23 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Good job!!!!
jhobbs26
Jan 8, 2024 12:59 PM
iverger
Nov 21, 2015 08:46 AM
429 f-100
Jun 23, 2011 06:00 AM
redman84
26
Dec 3, 2010 10:55 PM
granny_rocket
Apr 7, 2010 11:27 PM
