10 PSI @ FPR?!?
Old Oct 27, 2010 | 09:16 PM
redman84's Avatar
redman84
10 PSI @ FPR?!?
I couldn't get a reading with any tire pressure guages. I bought a fuel pressure guage kit from Harbor Freight (part#92699). I replaced all the o-rings on the FPR with new ones from Bob and put it back on. When I screwed on the guage and cranked the truck it read 10 PSI at idle and like 11 at 2000 rpms. I didn't really believe it but dropped a BB in anyway to see the effect and nothing, I got the same readings. Any ideas or advice? I don't think our trucks will even crank with 10 psi so surely it is a faulty reading. I also thought that maybe the brass nipple wasn't in the spring straight and checked it several times.
Old Oct 27, 2010 | 09:23 PM
fordpride's Avatar
fordpride
Mine has 12 psi at idle my fuel pump is only 6monthe old from napa so i'm not going to chang it till it dies or till right before the warranty is up i have a bad idle and when i punch it it falls on it's face
Old Oct 27, 2010 | 09:37 PM
redman84's Avatar
redman84
Well that's disheartening. I don't feel like it has a bad idle but it could be smoother and it sure doesn't respond like I want it to when I punch it. Well CRAP. So could it be a sign of a fuel pump on the way out?
Old Oct 27, 2010 | 09:50 PM
fordpride's Avatar
fordpride
yep, idid the same thing you did i cleaned the FPR and new orings in FPR and fuel bowl and nothing changed
Old Oct 27, 2010 | 09:59 PM
redman84's Avatar
redman84
Well that's about right. Everything else has just been going too well with Redman lately. Thanks for the heads up Mike.
Old Oct 27, 2010 | 10:02 PM
fordpride's Avatar
fordpride
my pump has been like this for 2 months now
Old Oct 27, 2010 | 11:57 PM
strokin'_tatsch's Avatar
strokin'_tatsch
Hmmm.. I didn't even think these trucks would run w/ 10psi... something not right about that... The spring in the FPR wasn't broken or anything was it? I would suspect an FPR problem over the pump. Usually when these pumps have problems they will leak wayyyy before they start dropping pressure. Mine had good pressure when I bought my truck at 250k miles, but it leaked..
Old Oct 28, 2010 | 06:48 AM
rideracelivemx7's Avatar
rideracelivemx7
time for....electric fuel!
Old Oct 28, 2010 | 09:36 AM
bad12jr's Avatar
bad12jr
Mine was leaking with 50 psi. With no bb mod.
Old Oct 28, 2010 | 11:38 AM
redman84's Avatar
redman84
No fuel leaks anywhere, knock on wood. My pump is only like 30k miles old.
I'd LOVE electric fuel but if they are all near the price of the CPR system then there is now way in he!! I'll be getting it.
Old Oct 28, 2010 | 02:14 PM
strokin'_tatsch
You can build your own setup way cheaper. You can even come look at mine to get a good idea of what you will need and how to run everything.
Old Oct 28, 2010 | 05:28 PM
redman84's Avatar
redman84
I might take you up on that at least to get a ballpark price. I wanna do a project at Cody's sometime anyway so maybe then if I can ever get away. What area of Austin do you live in?
Old Oct 28, 2010 | 05:45 PM
strokin'_tatsch
About half way between Austin and Dripping Springs off Hwy 290 W.
Old Oct 28, 2010 | 06:01 PM
bad12jr's Avatar
bad12jr
I've gotta figure a price total on what mine cost but i think it was around $550 or so total for pump filters and all.
Old Oct 28, 2010 | 07:41 PM
fordpride's Avatar
fordpride
even if i shim mine the pressure will not come up
