ABS wire
Old Jul 17, 2008 | 07:46 PM
King0581's Avatar
King0581
When you start it the light will go off for a couple seconds then come back on and stay. I wont even thinking i could have used my Edge to pull the codes. I went to my folks house to use my dads code reader. Both of them say no codes. So I have run the truck about two miles since I unhooked the batts. I would have thought it would have stored the code again by then.
Old Jul 17, 2008 | 07:50 PM
King0581's Avatar
King0581
Just went out there and started the truck and moved it around in the yard and light was on and tried to pull codes with my programmer and nothing stored. Edit...Figured out the problem, neither of the code readers I have access to will read ABS codes apparently. Looks like I gotta find a better code reader. My guess is the sensor though. Think I'll just pick one up tomorrow and put it on.
Old Jul 18, 2008 | 08:36 PM
King0581's Avatar
King0581
Well just to keep you guys posted i put a new VSS on it today(was at the parts house for some stuff for my backup lights so I picked one up). Not the problem. Gotta get it on a better code reader. If whatever is wrong with it is real expensive then I'm taking the bulb out and using that money for other mods! I got enough since to let off the brakes if they lock up and I loose control!
smittys5xs
1978 - 1996 Big Bronco
Mar 12, 2015 10:11 PM
GulfcoastSD
Dec 6, 2011 08:27 PM
c125bob
Sep 20, 2008 09:40 PM
jkdank
Aug 6, 2008 08:38 AM
fordblue_ca
Electrical Systems/Wiring
Feb 14, 2004 04:16 PM
